ZO6 air intake
ZO6 air intake
My neighbor has a stock air intake off of his 09 and said if I wanted it ,I could have it.I have a 09 Coupe with the Z51 accessories.Would I get any increase in performance if i installed it on my car? Thanks for any replies. Rod
It may help a little. but biggest difference between the z06 intake and the stock ls3 is the z06 does not have the silencer box on it. I would take it and put it on my car if only to clean up the look of the engine bay.
I did this. They use the same air filter and the intakes have the same profile so the flow between the two will be basically similar. You'll lighten your car by a few pounds. I don't hear any difference in the sound that it makes, though it would be hard to hear any change over the NPPs. But I agree with Tikiman that it helps significantly clean up the look of the engine bay.
yes it will flow a bit better. If you decide to put a new filter - the ZR1 will fit, and was tested but to make a couple hp over the original ls3/ls7 piece.
I put one on my 10 vert 6 speed manual , not only does it look better , it has a lot of intake sound (what I wanted) and I believe it runs better . (I have a diablo tune in it )
I have the one I took off my 2009 ZO6 I would sell-I replaced it when the car had maybe 500 miles-So it is basically new.
$100 plus shipping.
pm me or email @ dgvette@sbcglobal.net
$100 plus shipping.
