Pros/Cons Edelbrock Supercharger / 2011 Grand Sport
Hi all, I am thinking about putting in an Edelbrock E-Force supercharger on my 2011 Grand Sport. The fact that there are 2800 possible error codes and the sensitivity around the tuning kind of scare me a little bit. Would welcome any comments on reliability, performance and other issues experienced with this supercharger or alternative options, respectively
I wouldn't worry about the error codes as long as someone who knows what they are doing installs it.
have you looked into and A&A or ECS blower? easier power curve for the street and much cheaper to install and tune...and to take off and resell.
something to look into.
The tuning isn't an issue because the kit comes with a tune from Edlebrock that's better than any tuner can do on his own.
Get the supercharger!
Douglas in Green Bay
Former Vendor
1 Post
St. Jude Donor '10-'11-'12
The Edelbrock kit is a decent one, we offer it with perks for a good deal. I would look into the supplemental warranty Eddy offers with it.
It has 3 different level of coverage and unless your made of money its a good cover your butt program should anything go wrong.
Personally I would build the bottom end proper before boosting but I now so many people don't. for the most part as long as you keep the boost low and don't beat on it your being safer.. But we're rebuilding someones E-Froce engine right now who didn't beat on it....
little bad gas is all it takes to get some detonation and when that happens it effects the piston... get it happening one to many times and the piston shatters and the rod takes out the block. That is a real potential.. the engine has improper compression to be running boost ... but again low boost people get away with.. and then some dont..
that is the most honest answer you will get.... its a risk plain and simple.. there is a real good markup on s/c kits so there is a good reason to sell them and pimp them but the risk is real. I cant in good conscience sell a s/c kit without explaining all that.
That being said there are bandaids like a meth kit to help with this. But the more systems you add the more points of failure potential.
Meth kit + Eddy supplemental warranty is what i would look into if your going to do it. We can set you up with it all for a good deal if your interested.
Edlebrock spent hundreds of hours on the dyno getting it right. What other tuner has spent hundreds of hours tuning the Edelbrock supercharger with the C6 Corvette?
15 years ago it was more reasonable to have even your stock Corvette tuned on an individual basis because the HP output varied from car to car. Todays engines are built to tight tolerances and actual HP results are nearly identical but read higher or lower because of inacurate dyno numbers
If your engine needs additional tuning beyond the Edelbrock Supercharger tune then you should inspect the engine compression, plugs, injectors, valves etc.
Hope this helps,
Hello,
Hope this helps,
Hope this helps,
St. Jude Donor '09
Hello,
Hope this helps,
Hope this helps,
San
Insane really...explain why...
Can a custom tune be better? Sure...is it $500 better than the tune you already paid for in the box? I guess it depends on your definition of better.
There is also the question of what happens to the additional cost warranty Edelbrock offers if you choose to purchase it and then had the car custom tuned. I think it goes bye-bye.
As for me running a canned tune. Not a fair question as the car has a different size pulley, larger injectors, a cam, headers, and a 160 t-stat. I did start with the tune from the box though and built from there. There are two others that I've put together that are running 100% stock canned tunes on otherwise 100% stock cars and both owners are supremely happy with the results.
From where I stand I see custom tuning a 100% otherwise stock car that has the Edelbrock canned tune just about equal to tuning a 100% stock GM off the line Corvette which shipped with a 100% GM developed canned tune. Sure there is more there when done properly...but is it worth it? Personally I don' think it is worth the expense.
Change the car's setup though (headers, cam, etc.) and of course the tune has to change.
My two cents worth
St. Jude Donor '09
I guess it depends on your definition of better. If you mean from the perspective of eeking more horsepower out of the tune...of course there is some left on the table. The Edelbrock tune has plenty of conservatism in it. There is always room to tweak fuel, spark, torque and trans values but typically these come at the expense of longevity and unfortunately, often come with drive-ability issues. I've gone back in and retuned two Edelbrocks that were "custom dyno tuned" and had drive-ability issues after the tune. Oh and both of those came from vendors mentioned in an earlier thread. I've also fixed probably a half dozen amateur hacked "tunes" on the Edelbrock...each of those were totally AFU!
My two cents worth
My two cents worth
I would also add that even same model year cars with the same specifications are different. Sometimes slightly different, sometimes significantly different. Factory freak comes to mind.
San
That's correct, the original question was about adding Edelbrock supercharger to a stock C6 Corvette. And the answer I gave was and is the best advice.
Sure a good tuner could still gain a few more horsepower with the Edelbrock Supercharger but at the cost of engine longevity and possible drivability.
The C6 A6 is an excellent example, people like to disable the torque management. And if they drive aggressively they will be buying transmissions.
Bottom line: Some people are willing to sacrifice longevity for an extra 10 hp bragging rights. Many of us on the forum are not!
Hope this helps the gentleman who original posted.
