Dropping Cradle Using Ramps
Old 11-28-2015, 06:12 PM
R3DH0TV3TT3
R3DH0TV3TT3's Avatar
Default Dropping Cradle Using Ramps
Can the engine cradle be lowered while the car is on ramps?
Old 11-28-2015, 06:29 PM
blkbrd69
blkbrd69's Avatar
No.
Old 11-28-2015, 07:34 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
Sure, if you use a 2 post lift to pick up the body from the sides.
Old 11-28-2015, 10:19 PM
R3DH0TV3TT3
Originally Posted by blkbrd69
No.
I haven't climbed under the car yet to look so it looks like I'll be breaking out my jack and stands. Thanks.
Old 11-28-2015, 11:04 PM
Joe_G
Joe_G's Avatar
St. Jude Donor '08
I'll try to be a bit more helpful... look at RPMextra's thread here. Picture 14 shows how the cradle comes off...it is similar to the rear cradle too as shown therein.
If you need any help or tips post up, folks will help. What are you trying to do?
https://www.corvetteforum.com/forums...full-pics.html
R3DH0TV3TT3 (11-29-2015)
Old 11-28-2015, 11:08 PM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
The lower A-arm connects to the cradle, so you can't remove the cradle without disconnecting the lower A-arm. Disconnect that and you won't be rolling far..
Old 11-29-2015, 08:10 AM
R3DH0TV3TT3
I'm going to be pinning my crank in preparation for a Procharger.
Old 11-29-2015, 11:16 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Support the car with jack stands on the frame rails..
Loosen the 4 nuts holding the front cradle in place and remove the two nuts on the bottom of the engine mounts (easily accessible from under the car)
Use a pry bar or whatever to lower the front cradle as much as you can without removing the nuts.
Use a jack with a piece of wood or something on it to raise the engine as high as it will go
Voila--you now have enough room to get to the balancer to both remove the bolt and pin the crank. No rack removal needed.
Check out the magna charger instructions. Starting at step 59..
http://www.carid.com/images/magnacha...structions.pdf
Old 11-29-2015, 04:40 PM
R3DH0TV3TT3
Now that I have the car in the air I can see it. Thanks for all the help guys.
To Dropping Cradle Using Ramps
Quick Reply: Dropping Cradle Using Ramps
