[Z06] failed rocker chewing up the top of the valve?
When the dealer had the valve covers off to replace the two rocker arms with broken needle bearings I got to come by and take a look and snapped some pictures.
The top of one of the valves did not look right to me and today I finally had time to sit down and study the pictures and this is what I found:
Here is a normal looking rocker arm and intake valve top:
Here are two pictures of the bad intake rocker arm with the suspect valve top (note that the rocker arm is just loosely placed and the screw is just started, not tightened down so the rocker arm alignment may be off because of that, in addition to all the needles/rollers missing from the bearing on one side):
On another forum it was suggested that the failed rocker arm had been chewing up the top of the valve, which is what it looked like to me too. What do you think?
-kg
-kg
-kg
-kg
Your car is an '07 if I am not mistaken?????
Former Vendor
I said it before and I'll say it AGAIN! Please do yourself a favor and replace those stock rockers, and drive worry FREE!
We offer an option/cure to your problems...see the link below. No sales pitch here, this sells it self!
Thanks,
Carlos
Thanks,
Carlos
Do yourself a favor and remove all your rocker arms and send them into Harland Sharp for the modifications, this will alleviate any future issues. Also FYI HS is coming out with a all new full roller LS7 rocker arm replacement which will be coming out soon, it is currently in beta test. I am to receive a set for testing in my personal car.
Needle bearings adios - pushrod then forces rocker to move out of intended plane of motion - beats crap out of lash cap/valve stem tip - eventually resulting in dropped valve and/or possibly wallowed out pushrod holes in head. (Don't ask me how I know - at least it didn't happen with my LS7 yet.)
I guess the question is how much, if any (I can alwas wish...), of the valve top that was chewed up after the lash cap was gone.
-kg
Former Vendor
GM will only take the cheaper way out...that is why I rely on ME to take care of any potential issues.
As you may know, you MUST remove the heads if you need to replace the valves, and that cost GM money. When dealing with warranty work, those goofballs always seem to have a way out of fixing the entire mess the right way...red tape crap
Just remember that in the end, you are going to end up with the same mess that broke in the first place. So why not replace it with the upgraded units from HS and called it day.
Thanks,
Carlos
RIGHT!
Thanks,
Carlos
Thanks,
Carlos
It isn't GM that would intentionally do that. Its the tech working at the dealer and its up to him to properly report that the valve tip was damaged. If he don't say a word no one is going to know any better. GM isn't going to sit there "knowing" that the valve tip was damaged and not do anything about it. The dealer I work with and refer people to has done nothing but top notch work, they would never let something like that slide by.
Also as far as upgrading rockers, seems like a batch problem, so upgrade to a good one would be as good as an after market one. That way you don't risk loosing your warranty. Now before you flame the stock ones, with the exception of that apparent bad batch they work just fine. Got over 350K miles with 2 LS1's and 1 LS2 and the LS7 with zero problems. So I suppose I could take the advise of someone I don't know on a product that I don't know and replace them, been down that road before. As I've posted before, over 1 million miles with 9 Corvettes and the only problems I've EVER had were with the aftermarket fixalls.
Harland Sharp has been an excellent supplier of quality products to me for some time, granted even they will admit that they did have a issue with the LS1 rocker arms way back when they were first introduced, since then there has been no other problems.
All are saying the 06 Zs are safe in this area, but for my own peace of mind I am going to change my rockers. Hmmmm $70,000 investment in fun, and only a few hundred for the insurance for the life of the car. no down time and hassles with warrentee OR NOt.
I am in this vette for the long haul, and will pay to pre repair parts that will or will not fail early.. My 98 C-5 had bearing failure as well.
just my thoughts..
ITS SNOWING AGAIN IN BEND OREGON. COME ON GIVE US GOOD WEATHER, I WANT TO DRIVE....
just my thoughts..
Isn't the LS7 the only LS engine with a dry sump and remote oil cooler, and therefore the oil heats up much, much more slowly than the other LS series engines? It makes one wonder if beating on it before the oil gets up to operating temp (which takes a *lot* longer than getting the coolant up to operating temp) might have something to do with it. I wonder if the bulletin covered all the engines mainly because the rockers are the same design (and I think they are), or also because GM had experienced failures on the other LS series engines as well. It would be interesting to know what the failure rate is on the LS7 compared to the other LS engines.
