C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Norris Motorsports VMax CNC 2005-2011 Throttle Bodies Available - $149 Shipped
Old 10-26-2010, 07:32 AM
0Mike@NorrisMotorsports
Former Vendor
Mike@NorrisMotorsports's Avatar
St. Jude Donor '11
Default Norris Motorsports VMax CNC 2005-2011 Throttle Bodies Available - $149 Shipped
Hey All,
I wanted to bump this back to the top and as an FYI, the free shipping offer expired some time ago, but I wanted to bring this thread back up for everyone.
It has been about three years since Pete from Vmax and I introduced our CNC'd factory throttle bodies and the response was and still is great. Close to a year ago or so we also added the 2009 and up TB's in a full CNC version. This took a lot longer then expected, but well worth the wait.
For alot more info you can check out the original thread here in the C6 Tech forum. Here is that link for folks:
http://forums.corvetteforum.com/c6-t...9-shipped.html
The pricing is $149 plus $15 S&H and the refundable core fee. For the 2005-2008 versions, the core fee is $400 and for the 2009-2011 versions, the core fee is $200 for now. This VMax CNC TB is the factory 90mm unit used on all LS2, LS3 and LS7 engines. We also have a CNC version of the ZR1 TB's for those folks that runs $200 plus a $300 refundable core fee.
Please feel free to contact me here via PM or email me at thevettedr@aol.com and I will answer you ASAP.
Mike Norris
Old 10-26-2010, 01:19 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
If I installed one of these on my stock 09 Z06, would I require a tune? What kind of HP increase could I expect?
Old 10-26-2010, 01:51 PM
Uncle Meat
Uncle Meat's Avatar
Bad link.
What's the benfit of switching to this TB?
U.M.
Old 10-26-2010, 09:45 PM
Former Vendor
St. Jude Donor '11
Sorry about the bad link and it is fixed now
All of the info you are looking for is in that thread, but I can post some simple answers here.
JoesC5, on a bone stock Z06, it should install no problem with no tuning and yield 9-12HP and a noticeble increase in throttle response.
U.M., the same would be for you but without knowing what engine you have I do not know what HP gains you can expect.
Quite a few C6 owners have also mentioned that they had gained 1 to 1.5 more MPG's, but I have yet to test for that. This could be a result of the spiral cutting that was achieved.
Hope this helps and thanks.
Mike Norris
Old 10-28-2010, 06:47 PM
Griffee
Griffee's Avatar
Old 10-28-2010, 09:27 PM
OJCrush08
OJCrush08's Avatar
How well would this match up with either a ported stock intake or FAST intake. I would think that they would work together to produce a bit more power that with the totally stock intake and this unit. Any experience with this?
Old 10-29-2010, 07:05 PM
Former Vendor
St. Jude Donor '11
From what we have seen, the general answer is that it will work well. The potential issue can be on the actual port work. There are quite a few "Wanna Be" porters out there that can actually do too much in the inlet area and cause a disturbance, but this would cause an issue with a stock TB also.
If at all possible I would get a ported "set" of an intake and a TB to be sure what you are buying is compatible. Of course if you already have a ported intake, going ahead and getting a ported set may not be in the budget.
Hope this helps and just let me know. Thanks.
Mike Norris
Old 10-29-2010, 07:51 PM
Nolyaw
Nolyaw's Avatar
Is that 9-12 at the tire, or flywheel?
Old 10-29-2010, 07:55 PM
Geared
Support Corvetteforum!
Geared's Avatar
I have a question, and I hope it doesnt come across as bashing this product AT ALL. Mike Norris is awesome at what he does....but
How can this possibly compare (power, driveability, etc) to throttle bodies which are 3-4 times as expensive - in particular the NW TB's.....
thanks.
jb
Old 10-31-2010, 12:23 PM
Former Vendor
St. Jude Donor '11
Nolyaw,
That is 9-12 HP at the tire on an otherwise stock and untuned C6 Z06.
Geared,
No problem and a great question. I do not generally see anyone buying an NW TB, which is an excellent product, to just replace a stock TB. Usually the NW comes into play when you are going to a larger intake and than the factory size and a larger TB is needed. This would be a C5 going to a 90mm or 92mm setup or a C6 going to a 102mm setup as examples.
Now one thing we have seen is that folks going to 102mm intakes will, in most cases, not have an aggressive enough combination to utilize a 102mm TB. We have found that a 102mm intake equipped LS engine will work better as far as driveability and throttle response and equal HP when using a VMax CNC TB and velocity ring versus a 102mm TB.
Hope this helps and thanks for the kind words.
Mike Norris
Old 01-16-2011, 06:30 PM
Former Vendor
St. Jude Donor '11
Bump for the new year. The sales on these units have been very good to say the least.
Thanks to everyone for a great 2010 and looking forward to the same for everyone in 2011
Mike Norris
Old 01-16-2011, 09:55 PM
Nolyaw
Nolyaw's Avatar
email sent
Old 01-17-2011, 09:00 AM
Former Vendor
St. Jude Donor '11
I did get an e-mail when checking this morning and guessing it was you. Reply was sent and just let me know.
Mike Norris
Old 01-19-2011, 09:43 AM
BubbaDuss
BubbaDuss's Avatar
I can vouch for a Stock 09 with this.
I Got my throttle body ported by Pete through D Revolution Motorsports here in Davie.
Throttle response is easily noticeable. My car is not tuned, just a KB and Beehive. Best $150 I have spent on the Z.
Old 01-19-2011, 08:32 PM
Former Vendor
St. Jude Donor '11
Thanks for the testimonial
Mike Norris
Old 02-10-2011, 04:19 PM
corvettejoe09
corvettejoe09's Avatar
Just received my TB from Vmax today. Pete does quality work, installed, torqued the bolts, ran the car up to temp, ran great, no idle issues. Instructions said could have changing of RPM at idle for a bit, but with late model, shouln't have. Very happy!
Joe
Old 02-10-2011, 07:39 PM
Former Vendor
St. Jude Donor '11
Glad it worked out well for you Joe and thanks!!
Mike Norris
To Norris Motorsports VMax CNC 2005-2011 Throttle Bodies Available - $149 Shipped
Old 03-28-2011, 10:28 PM
show723
show723's Avatar
Would a tune be required if I went with this tb and halltech's fiberglass 102mm intake?
Old 05-19-2011, 08:49 AM
Former Vendor
St. Jude Donor '11
Just a bump for folks as there were some shipping fee changes as well as some core fee changes that needed to be made. All of this info is is the first post for folks.
Thanks for the years of support and have a great day.
Mike Norris
Old 05-19-2011, 11:13 AM
DRLC5
DRLC5's Avatar
Mike bought one of these TBs for my 08 a few years ago and you are correct the throttle responce was greatly improved I want one for my new GS LS3 can you tell me how long is the wait? and what is the turn around for my core? Thanks.
Quick Reply: [Z06] Norris Motorsports VMax CNC 2005-2011 Throttle Bodies Available - $149 Shipped
