Splash guards
Same with the Level 1 GM front splitter everyone is putting on the Stingrays.
E-Ray, 3LZ, ZER, LIFT
Received 9,671 Likes
The OEM's do nothing for rearward tossing, only sideway-outward projections. I slotted the bottom of the OEM to add an extension I cut from flat splash guards found to Pep Boys. They are level with the ground the camera makes them look angled. Unless you are looking for them they blend right in.
Bought the GM OEM splash guards
Installed them in the driveway.
Did not have to remove the tires.
They fit and look great.
Took less than 5 minutes per corner.
Protection is minimal but I like them.
Not as effective as the Yosemite Sam "Back Off" mudguards.
You can do it in a parking lot after you pick up the car in <1/2 hr.!! No need to jack up the car. I make PDF's of my installs for non DIY folks but you might like to see so you bring the few tools you'll need.
http://netwelding.com/Splash_Guard.pdf
same here at least you get some extra protection. You have to wonder why GM doesn't just install the guards at the factory they hardly look any different on the car.
#33
Premium Supporting Vendor
The GM Accessory guards are black in color and we would be more than happy to assist anyone with them pictures and pricing can be seen here
http://www.cultragfactoryparts.com/c...splash-guards/
__________________
Patrick Trageser
CULTRAG Performance
Your one stop source featuring the true experts for all GM Parts and Accessories, Lloyd mats, SLP Performance and Hawk Brake pads!
Order Your GM Parts at www.CULTRAGfactoryparts.com
patrick@cultragperformance.com
1-484-334-8833
CULTRAG Performance
1-484-334-8833
#38
I got the GM OEM off Flea Bay (cheapest I could find) and used a rattle can to paint them body color just on the thin strip that shows. Cover over the entire splash guard with plastic bag except for the area you are painting. Apply a few coats of Plastic Adhesion Primer from any auto parts store, a few coats of body color, and a few coats of clear. Mounts easy.
The only mistake I made, and I will eventually do over, is sand the area to be painted completely smooth to get rid of the grain pattern molded into the part before you paint it. It will look much better.
#40
