Quality blindspot mirrors?
I have some quarter-round ones that fit and look good on the side-view mirrors of the C7.
They don't cover the same area as the full-rounds, but they swivel so are adjustable.
And yes, my mirrors are correctly adjusted.
Personally, I don't want cameras or radar detection of the lanes next to me.
When I went from the C6 to my C7, I had real concerns about blind spots. But after reading a thread on here about proper adjustment of the C7 mirrors, I am pretty confident in changing lanes. Proper adjustment works very well.
The purpose of your side mirrors is to be able to see the "blind spots" of the car. If you have it adjusted to see anything else, you're doing it wrong. You shouldn't be able to see the sides of your car without leaning your head all way out to the threshold of your window.
One nice thing about these is that they show a sliver of the second lane over, which has helped avoid a "both cars move into the same space from opposite lanes" situation.
This is a classic example of not having your mirrors adjusted correctly! You can see the side of the car in the lower right of the mirror.....if you need a spot mirror to see a car that is directly along side of you (as in the photo), you better turn in your keys.
if you ajust right and get used to it it works well have someone walk in the blind spots while you sitting in the driveway with you mirrors ajusted like this and see how much better it is WORKS FOR ME
Twisted Swifter (05-29-2016)
Received 3,447 Likes
Yes. If drivers would follow these instructions, no blind spots exist. I have been using this method for years now and once you get used to it...you'll be fine. Just give it a chance.
Bsm
I recently got a C7 Z06, which I love, but the blind spots (even with mirrors adjusted with what usually works well, aka none of your car in view) are pretty rough in the Corvette.
I also have a 2011 Mustang GT, and it has these mirrors by default - http://www.mustangheaven.com/blog/wp...9-1024x764.jpg
Is there an insert that I could get for the Corvette to have mirrors like this? Or a quality blind spot mirror from the aftermarket to plug on because the ones I've seen are all cheap and ugly...
#33
E-Ray, 3LZ, ZER, LIFT
Received 9,662 Likes
I have used that system in the graphic posted by several here since it was defined in a technical paper in SAE in ~1995! It is much more comprehensive than just seeing the car as it enters the "blind spot."
Read and understand the discussion on the right hand side of the graphic in post #30 and #31, it outlines some of what the paper defines. It's knowing where cars are all around you at all times. The text (which some don't appear to read) says you follow a car from the center mirror as it enters the "blind spot." That requires a wide view in the rear. Verts, for example, have a very narrow rear view with the top up. The C7 is worse that the C6 and many prior Vettes. I did not add them to my '88, '93, or '08 C6 because it was not needed.
In 50 years of driving I have never had an accident with an other car (looking for wood.) I attribute that to luck and being aware of all cars around an approaching me at all times (yep, I drive fairly aggressively and part of that is looking for patrol cars!! )
That means following, without loosing them from the center to side mirrors!
Cberry2 (08-22-2016)
#35
My wife's new acura on the LH mirror they bent the edge, about 1.5" or so, you can see the line they put on it. So just that portion of the mirror is convex, just like a blind spot mirror without the ugly stick-on look.
Be pretty cool if someone did aftermarket replacement mirror glass like that, unfortunately with heat and auto dimming probably wont happen except OEM. Thought it was an interesting solution, the acura has blind spot monitoring as well and it needs it with the huge rear pillar blind spots. Personally I have no problem with the C7 and blind spots but I seldom drive in heavy high speed traffic, plan my lane changes well in advance and the mirrors are adjusted way out.
#36
Received 2,639 Likes
I understand the eye sight thing brother, but luckily I can still see the pass. side good enough. I know they are unsightly, but I bought two small ones from Wally World. They are better than nothing in my opinion. Not being super human, I need all the help I can get.
#37
they do, just not on Corvettes.
GM does a lot of things that don't make sense, the Cruze has LDW and BSD (optional) but does not offer it on it's halo car, it seems to me that they need to do focus groups if they truly want to sell vehicles equipped with what people want. Imagine that, actually listening to and doing what people want.....
#38
I got mine at walmart. I think most auto parts stores carry these as well. There is nothing special about these except the chrome frame instead of black, which is more common to find.
#40
