NPP Help!
Good luck I hope you can work thru this as many others I am sure would like to do this mod
Its could be a stepper motor if it has a learn procedure, like an IAC motor. If its a stepper motor then it wont work without some kind of PWM.
If you look at the wiring diagram the front actuators have what appears to be feedback to the CCM (pin 3), its hard for the CCM to know where the motor is without some kind of feedback but it can figure position from where it stops on both limits by counting pusles.
I could easily build a PWM driver if its a stepper motor, if I ever pick up a NPP with the rear valves my main interest would be getting it to work with the CCm/factory setup. I'm sure in a year or so there will be a lot more NPP systems for sale and i may pick one up to play with.
But I'm not going to go through all that until I have an NPP here to put on
The stepper motor makes sense but its not the fastest way to go, I'm not sure how long it takes for the rear valves to go from open to closed, I know the front AFM valves are pretty quick, thats why I just ASSumed they were pretty much on or off.
The CCM is there, and 12V is easy enough to get. Most likely the pin on the CCM conenctor isnt populated but I have pigtails that will work, then I can just hook a scopemeter to it and see if there is any activity with sound management on or off. I doubt it will be active since it appears if you unplug the rear actuators on a NPP car you will get a CEL, so I have read anyhow.
I wouldnt mind getting my hands on an actuator to play with though, little too expensive to buy new just to experiment with
I would just think a stepper motor would be kind of slow, but I guess it really doesnt have to be super fast since its just controlling noise. The front AFM valves seem to be pretty quick but you get a 'burp' that lasts a second or so if you are right between V4 and V8 and the right amount of throttle.
No good to me this way!
I should send you one of my $310.00 motors as it is a paperweight right now!
Before throwing in the towel....you have a lot invested already try one of these....it should work.
#33
I'll find an actuator eventually, I wouldnt want to burn up one of yours experimenting.
#35
Take a look at the standalone PWM module....I believe that should be the ticket for a npp conversion for simple open and close via something like mild to wild
#36
St. Jude Donor '14-'15
I think you might have nailed it here. If so, this would work for both sides, as well. (non-NPP to NPP, and vice versa).
I might have to play with this for $11.
#37
The PWM control may work, but I think its a stepper arrangement and if thats the case its not pwm but just a certain number of pulses to reach a desired position. Only thing about that is it would have to reverse polarity to the motor to go the other way, but it may just remove the ground to reset the motor and start over since its spring loaded.
Hard to tell without actually having an actuator though
#38
Edit re read...you mean the actuator it self...got it.
Pretty sure that covers it
#39
But stepper motors use a set number of pulses to control them.
Most stepper motors take 200 pulses for one complete rotation, so if you need 180 degrees the controller sends out 100 pulses and stops or holds power until the next change is needed. Thats how they can work fairly accurately with no feedback.
It may work for a simple open/shut, only one way to find out.
