Need help, where can I buy Speedbleeders + Stainless Steel Brake lines
Could someone help me recomend an online shop.
I need to buy a set of speedbleeders and a set of Goodridge brake lines, but I need to get them from one source so I can use only one shipment to Mexico city.
Please advice, I have found the items in different online stores.
Thanks guys
Thanks guys
Platinum Supporting Vendor
What year are they for?
The Corvette Forum Store carries most of them...
C5?
Speed Bleeders
Stainless Lines - These aren't Goodridge but are exactly the same.
Edit- Looking at your avatar I'm guessing C6
I don't have speed bleeders for C6, but do have the lines, sorry
C5?
Speed Bleeders
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles
Thanks for the replies.
I have a 94 Vette. I made some research and found out that Earl's lines could cause problems with ABS setting trouble codes.
And found out that Goodridge would give me a trouble free operation and instalation.
That is the main reason to use exclusively Goodridge against other brands. Because I live in Mexico city I need to buy a product that will work the first time and not regret it later.
Thanks for the online store recomendations, so far they do not have Goodridge lines, but I hope someone will have a place that carry this brand.
Thanks very much for the advise!
Try Merle at exotic muscle: http://www.exoticmuscle.com/webpage.php?EMCAT=vette
I bought my Goodridge's from him, but I did buy my Speedbleeders directly from www.Speedbleeder.com
I am very satisfied with this combo, you won't go wrong.
Kinkajou, you may want to consider a motive power bleeder as well (www.motiveproducts.com). I had speed bleeders on my 93 and although they worked well I would highly recommend the motive power bleeder over them.
Doesn't really address your one stop shopping issue though.
Using the Power bleeder with 12-15 psi will open the ABS modual in the caliper and pushes the brake fluid though.
So my speed bleeder is a 10 mm Craftsman open ended wrench.
To flush the brakes you need to open the ABS modual in the caliper. To My Understanding, speed bleeders and the Mini-Vac do not do this.
Maybe I still have air trapped in there that can only be removed via pressure bleeding.
I did not consider this.
Thanks!
