diy harness bar...single alu bar enough?
I was looking at ecklers.com and came across a harness bar that consists of only one aluminum bar (I'm assuming it's solid):
http://www.ecklers.com/product.asp?p...0&dept_id=1618
Instructions:
http://www.ecklers.com/assets/pdf/45100.pdf?
Is that sturdy enough? Has anyone made their own in a similar fashion (without the vertical supports)?
Instructions:
Location: Vette Doctors Performance RX450 - 466RWHP !!!
I have the HARDBAR Harness bar and its One solid bar. No down supports. Nothing other then the Seatbelt Bolts! So it should be fine.
The one you saw on Eckler's site IS the HardBar from our buddy Gary Hoffman of www.HardBarUSA.com.
I have the HardBar too, and it is indeed a single 2-inch diameter aluminum bar. It's a sweet piece, and has been 'crash-tested' successfully in real track incidents more then a few times.
The Hardbar unit is not solid aluminum bar , it is a tube........If it were solid aluminum bar it would be as heavy as the RD crossbar that sperkins just bought. If I remember correctly the aluminum Hardbar is ~8 lbs. The RD monstrosity is~25lbs. Gary makes or did make real shiek carbon fiber harness bars that were~3lbs.
I made mine I used:
03-55300 4130 SHEET 6" X 12" X .125" $8.28 for the ends
03-10800-4 4130 STEEL TUBE 2X.065 4FT $26.40 for the bar
Total cost was $50 ordered from aircraft spruce. It's gas welded together to federal aircraft spec. It only weights five pounds. Pay very close attention to mounting points and hardware.
...It's crash tested so you know it'll work
HardBar = highly recommended by all that use it.
