Brake pad suggestions for '08 with Z51 option
I am looking for suggestions on brake pads from you experts out there for my '08 with Z51 option. At is a daily driver which I Road race once every 2-4 weeks so I want some nice pads that will work a bunch better than stock pads on the track and still work ok on the street. Fire away!
Hawk HP+ works great for someone just starting out. They are fairly cheap and work well as long as your willing to give up a bit on the late braking. The next step up would be the Carbotech XP8's. They work pretty well on the street and will give you a bit more bite/fade resistance than the HP+'s on track.
Either way, invest in a set of brake ducts. They will allow the: pads, rotors, and wheel bearings to last longer under track abuse. Oh an of course flush the system with some good DOT 4 fluid. There are many on the market that work well. I'm running Motul RBF600 and have had very good luck with it.
I recently got a set of Carbotech XP8's front, AX6's rear for my '08 Z51 for autocross and street use (though NOT for track use - I switch to another set of dedicated track rotors and pads for that). I found the initial bite, pedal feel and torque of the Carbotech's to be dramatically better then stock Z51 pads.
However, they do really squeal badly on the street with any heat in them at all, no matter how hard I lay on the pedal. Just the nature of the beast, I guess...
BTW - Danny at Carbotech will give 10% off to forum members. If you decide to go that way, give him a call.
Just put on a set of c5z pads up front (my rear z51 pads on my 07 seem to have plenty of thickness left) flushed the fluid with ate super blue, and put in a set of c6z ducts up front. We'll see how that does, if the pads don't work out I'll be switching to carbotech xp8s next. However I'm not so fortunate to get out to an hpde more than 3 times or so a year plus I'm not fast like most of the guys who do it regularly...thus I think the c5z pads or at the most xp8s should hold me over to get my occassional track jollies.
That being said, it's really easy to change pads on this car...maybe worthwhile to get a dedicated track pad + rotor setup if you're running every month.
I'll report back after my first day at the track...I had intended to do buttonwillow @ the end of January but the timing isn't looking favorable (I may be away on travel for work during that time). I will be at streets of willow early February and will see how it goes then. Wish me luck.
In all honesty, the z51 pads did quite well last year, only a tinge of fade but it was more a case of the fluid which let me down. Hopefully by having done both I'll be a ahead of the ball this time around.
I switched back over the Hawks for autox and have been extremely pleased. I have 5 events on them double driving the car and I can't visually tell they are worn at all. For track use in the future, I will be on either Hawk DTC70's or Wilwood H's.
Pads are also a personal preference type of mod. If you have the chance try several brands and compounds and see what works best for you.
Z06 front brake pads – 88952008 – 133.39
Z06 rear brake pads – 12530688 – 61.20
Also, which Hawks are you using.
Former Vendor
I too use the HP+ pads for the track, but I have Z06 calipers. The first set squealed extremely loudly, but the 2nd set came with some caliper grease that I put on the backing plates, and they are really quiet on the street. I imagine carbotechs would also quiet up with some grease.
Do you feel that the HP+ pads give you good stoping power in road race?
I took to swapping the rotors and pads on my C6 Z51. I tried PFC 01s, and Wilwood H compound. The Wilwoods were much better IMO, and I swapped to using the cheap NAPA rotors and the C6 base/C5 caliper brackets. The part number on the caliper brackets (abutments) are 12455800 and 12455799. You'll need to order 2 of each to do front and rear, and they're about $33/ea through Gene Culley.
It's really worth swapping out the rotor+pads if you're planning to run hard...
After looking closed to the official Hawk website, the HPP+ doesn't come in a Z51, only standard and Z06. Don't know if the site is not up to date or it is truth
C6 Base & Z51 FMSI Numbers -
D731 front
D732 rear
All pad manufacturers reference the FMSI numbers for backing plate shape & other specs when designing their pads. Then they apply their different pad materials to that shape (HP Plus, DTC70, Wilwood H, Wilwood E, etc).
You got me a little confused, which pads do you use for daily use? Which ones do you use on a road course like me?
And just like Mr. McCready - I switch to Wilwood H's for track days on road courses. Once you get them into their target temp range (which is MUCH higher then street pads are designed for), they really work well. So there's far less chance for pad fade when you're driving hard and using R-compound tires (compared to street pads).
Hope that makes sense...
Thanks for all the great information guys.
So would it be ok to run XP10 on front and XP8 on rear full time, I.E. daily driver stuff being OK? I would like to not have to change the pads constantly, would I still be able to stop on the street? Other than throwing money away would there be any other draw-back to just run those all the time?
XP10/8 combo works just fine on the street. Just remember it's going to take a couple hits to get the pads up to temp. They will stop "ok" cold but really need some heat to shine.
One nice thing about the carbo's is, the brake dust just washes right off
