High speed vibration at the track
I participated in a HPDE on the Roval at California speedway yesterday. I was experiencing a vibration at speeds over 135. For most of the day I thought that it was being caused by the high (30 - 40MPH) cross winds coming down the front straight into NASCAR turn 1. But, late int he day the winds finally quit....and I was still having the vibration. I looked at the tires and brakes, and checked for bearing play between sessions and everything seemed fine. I have not had a chance to dig into the car yet...Any suggestions?
To help with the diagnosis...My car is a stock '08 Z-51 convertible with Z06 body panels, wheels, and tires. Also I have a new set of Nitto Nt-05's on the front, and new DBA 4000 rotors. They have been on the car for about a week with no issues.
Thanks for the help,
Charley
Charley
CI 4-5-6-7 Veteran
If it comes and goes with the brake pedal, it's a cracked rotor. If not, it's probably slag on the tires or a missing wheel weight. The faster you go, the more you'll notice odd little things shaking and wonder if they are important as you approach that 150-30mph brake zone.
Happy thoughts.
Happy thoughts.
Hi Charlie:
Can you feel it through the steering wheel like it is coming from the front wheels or is it the rear?
For me, in order of what I think it would most likely be:
Oli
- Bent wheel, take them off and throw them on a balancer to see if they are bent. An alternative is to try and spin them on the car, but they usually bend more on the inside then the outside.
- It could be wheel weights...
- Re-check those hubs. It can be more than just a bearing. I have cracked hubs around the flange where it connects to the center of the hub.
- Cracked rotors, but those normally only feedback under braking. Sometimes you can feel them while just driving, too. ACS is a rotor cracking track.
- Check your end links and make sure they are all tight.
- Cording a tire. A corded patch will provide some feedback, but mainly while turning.
- Torque tube or cracked clutch problems...? Does it feel like it is coming from the drive train?
- Harmonic balancer on the front of the engine?
Oli
Along with looking for missing wheel weights, check if there's a big track turd stuck somewhere on the rim throwing it out of balance. Check the cheap stuff first. :-)
At roebling I had a vibration my first session on the out lap. As we picked up speed it got worse, Took pit road and back to the paddock.
Nothing broke, nothing bent, a whole mess of track turds though. Cleaned them up - next session back to normal.
Hi Charlie:
Oli
Oli
Thanks for all of the help.
Charley
CF Senior Member
Happy thoughts.
Happy thoughts.
I should have had on that list two other important things to check that could cause this problem:
- Loose lug nuts, especially on the front
- A cracked wheel spoke
Hmmm... How do I know all these things....? :o
I disagree. That definitely IS enough tire turds to cause a high speed vibration.
If you are grabbing the wheel at 3 and 9 and it is has movement, then it is likely tie rods.
