header wrap
Old 08-16-2010, 12:13 AM
wmckeenster
wmckeenster's Avatar
Default header wrap
Is it worth doing?
Pros/cons?
I have went through two starters now, I assume due to header heat and the fact that they are literally an inch away from the starter.
Is there a better, lighter race starter available or is there a starter "blanket" available?
Old 08-16-2010, 12:29 AM
longdaddy
longdaddy's Avatar
Originally Posted by wmckeenster
Is it worth doing?
Pros/cons?
lingenfelter makes a shield, or you can save $60 and cut one yourself out of ATE can...
I have lgf shield and already put twice the number of trackdays on the replacement GM starter compared to how many cooked the original one.
Old 08-16-2010, 04:03 PM
FKING1
FKING1's Avatar
Wrap will cause non stainless headers to rust.
Get a shield.
Old 08-17-2010, 07:31 PM
wmckeenster
Thanks guys, will use the LPE shield.
To header wrap
Quick Reply: header wrap
