2006 base c6 brake pedal height
2006 base c6 A6 brake pedal height
2006 base c6 a6 auto brake pedal too high
got a kirkey seat in my track car and want to lower the brake pedal height to the same level as the gas pedal cause i brake with my left foot and my left knee is higher than my right knee
anyone try this before?
any tips?
any tips?
carl3989 (06-09-2022)
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I haven't seen anyone lower the pedal height on the brakes, but most will raise the throttle to meet it under heel/toe conditions. I do not believe there is an adjustment on the master cylinder rod, but again I haven't checked that on the OEM setup.
I'd have to agree with anthony. I actually raised the pedal on my c5. I have yet to drive a production car that had the brake pedal too high. Keep in mind that under severe braking the brake pedal will most likely be lower or level, at best, with the throttle. That is not desirable on the track.
Former Vendor
The way I have seen it done is either with a composite or aluminum bolted to the gas pedal. Typically making it wider and taller. Shouldn't have to move it much. Event with stainless lines, and a hard pad on the car the brake is still going to fall at least an inch.
