helmet recommendations
I've never been to autox or the drag strip, but I will be going pretty soon. I need a snell 2005 approved helmet I think? I want an open face one because they seem to have the best visibility. Any recommendations for a decent cheap one?
Thanks,
- Vinnie
Thanks,
- Vinnie
Unless you have eyes on the side of your head, a full face helmet is just fine. Does a nice job of protecting your lower face in a nasty collision.
You need to go and try some on to get an idea of size. A lot depends on your $$$, from lower end Pyrotect are nice to Arai which are one of the very best...and dozens in between.
Snell standards are issued every 5 years. So the most current is 2010. Also, Snell standards can be M (for motorcycle), SA (special application, including racing), K (for kart).
Check with the clubs you would run with to learn what their standards are. Most probably M would be acceptable, but I would still suggest checking.
I'd suggest getting a SA2010 so that you have the most flexibility with what you might want to do in the future, and you have the longest possible time horizon with the helmet before it is no longer valid. It's not much more expensive.
+1. I've always had good luck with Bell Helmets. Not necessarily the cheapest, but I'm not a fan of skimping on safety items. Arais are really nice, but they're expensive and run pretty small. I haven't been able to find one that is comfortable to wear.
Received 8,929 Likes
Look at Impact and Simpson helmets as well. If you can find a race shop in your area go and try on several helmets, they all fit a little different even when the same size. If you want a really nice helmet try a Stilo at HMS Motorsports in Danvers but be sitting down when they tell you the price. The owner of HMS sells helmets and other safety equipment to Hendrick Motorsports for their NASCAR teams and is a recognized safety expert. He will tell you what you need to look for in a helmet for comfort, safety, etc.
http://www.hmsmotorsport.com/store
Bill
Bill
+1 on the Zamp. I wore out a G-Force before this one and the Zamp looks and fits just as good for less money. Might as well go with a SA2010 and you will be covered. Not sure if any clubs are mandating full face over open or not. Seems I read some rules at some place that indicated they required the full.
Just bought my first full face though and thinking the open face may better suit me. My old helmet was open face and while I have been hit with debris a couple of times I find I'm driving with the visor open on the new full face. The clarity isn't that great at least on the Zamp visor. It has some wavy distortions or something. Also the full face smells which I assume will eventually go away.
You have to try them on first.
I thought for sure I would get a Bell when looking all over the net but when i tried them on they kept rubbing the top of my forhead too much. I put on an HJC and it was PERFECT! It was also less expensive then the Bell M4 and looks sick in matt black. $300.
Also, the pads inside fit my cheecks nice and snug like I can almost bite them. It makes for a comfortable, snug fit.
I too would recommend trying them on first if possible. I have had Shoei, Simpson and Bell and each time I was surprised that the helmet I wanted, thought would be best, didn't feel right when I tried it on...maybe it is my odd head, but I always want to test them first.
Check the internet and you will find several stores selling the HJC FS-3 which is a open face motorcycle helmet rated Snell 2005 for around $70 bucks. And it's comfortable, at least for me.
the sa2010 is 300 bucks and will be useable until 2020
St. Jude Donor '05-'08
you lose light weight benefits, better materials and sometime comfort/fit with cheaper helmets.
That being said If you use the helmet all the time then I agree buy a more expensive helmet because those extras are very nice over the long run, but if you are going to use your helmet only a few times than a lower end SA compliant helmet will be just fine.
My first SA helmet was a Gforce. It was not expensive compared to others, but it fit my needs at the time.
Originally Posted by Snell foundation
While helmets are primarily a protective device, the true protective capabilities of a helmet, if needed will only come into play for about 2 to 4 milliseconds during the lifetime of the helmet. This leaves a lot of time for that helmet to be doing nothing more than sitting around on a user's head. Producing a product that meets the standards is not really very difficult. Producing a helmet that people will buy and wear, and will consistently meet the standards is significantly more difficult. The Snell Standards do not measure factors like comfort, ventilation, brand recognition or style, and only indirectly look at fit, weight, materials and workmanship. These are factors that frequently drive helmet cost.
FYI to the OP - I believe some places are now requiring SA Full Face Helmets. you will not have an issue seeing with a full face helmet. They even make ones with larger eye ports for people with glasses so maybe look into those if you are concerned.
I've owned hjc and aria motorcycle helmets. The Arai was allot more money. It's main benefits was comfort and lower wind noise. My road race helmet is a Simpson and its as nice as the aria. It is very comfortable and I Can wear it all day. It's also light weight, has a wide field of view, the shield slides up niceandstays up when I want it to.
Premium Supporting Vendor
Something to think about is basal skull fracture protection: e.g. HANs Device or similar. I personally won't get on a track without one, nor will I take a passenger without one. I don't think an open face helmet will provide the same level of protection as a full face when considering the front of the helmet is what holds your head from going forward when the helmet is stopped by the HANs device.
My own personal experience that I am here to tell the story of:
http://www.c66racing.com/Blogs/Safetygear.htm
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
