Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
The N/A Corvette Fast List
Old 05-11-2008, 11:52 AM
11secondGP
11secondGP's Avatar
Car/year 08 C6 NPP
Motor type/size LS3 6.2L
Suspension base
MT ET Street DRs
Race weight guess 3400 LBS
Trans type A6
Race track Sacramento Raceway
ET/MPH 11.67 @ 120.62
11.67 @ 120.62 - 11secondgp - 08 A6 - CAI, DR, ported int/tb, tune - (2740)
11secondGP is offline
Old 05-11-2008, 12:06 PM
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
This was my fastest naturally aspirated run..
Car/year.......................1968 Vette Convertible
Motor type/size..............23 degree headed 434 SBC - Built by RevXtreme
Suspension....................Moroso Trick front springs with Competition Engineering 90/10 shocks, rear 550 lbs/inch composite spring and QA1 shocks. Tom's differentials rear w/ spool and 31 spline axles and 3.5 inch half shafts
Tires............................front Moroso DS2 28 x 4.5 - 15, rear MT ET Drag 28 x 10.5W - 15
Approx. raceweight.........about 3000 lbs with me in it (estimation as I haven't weighted the car in a while)
Transmission type...........2-speed Powerglide - automatic
DA if known...................appox. 1000 on the 9.90 n/a run
Track...........................Bradento n
ET and mph...................9.90@136.42
GrandSportC3 is offline
Old 05-11-2008, 12:24 PM
GrandSportC3
The fastest 23 degree headed Vette that I'm aware of is Greg Eaton's..
His best naturally aspirated C3 ran the following:
1.3582 60
3.8289 330
5.9133 1/8 mile @ 119.21MPH
7.7183 1000
9.2490 ¼ mile @ 150.35 MPH
He runs mid 8's on spray.. maybe low 8's the next time out...
Here's what I know about his setup.. Hope that he'll chime in and post details..
Car/year.......................1970 Vette Coupe
Motor type/size..............23 degree headed 427 SBC
Suspension....................Don't know details but he runs Tom's 12-bolt IRS with spool
Tires............................not sure what he ran on that run
Approx. raceweight.........not sure
DA if known...................don't know
Track...........................Houston, I believe..
Old 05-11-2008, 03:34 PM
J Z06
J Z06's Avatar
Car/year.................2004 Z06
Motor type/size........LS6
Suspension..............Stock
Tires......................Good Year Eagle F1 Supercars
Approx. raceweight...3290 w/driver
Transmission type.....Manual MN 12
DA if known............?
Track.....................Englishtown
ET and mph.............12.25@117.
J Z06 is offline
Old 05-11-2008, 09:00 PM
hookedup
hookedup's Avatar
DOB/type-'90 coupey
Injun-approx. 22X22x28,small rusty cast iron, about 570#
Suspinsoon-squeeky-rattalin' home-made 4-link
Tars-round, black, 12X31 half full-o-air
Wait-48,357oz.
Transmisseyon-sometime 2spd, 3spd, late yesterday=no speeds
DA-?Unk.
Track-straight
ET-pick any below ya' like
hookedup is offline
Old 05-11-2008, 09:20 PM
0ski_dwn_it
Former Vendor
ski_dwn_it's Avatar
89 coupe
12 bolt solid rear conversion
30" radial slick
434 n/a, 23* heads, EFI single plane intake, 11.5:1 compression.
3320lb weight without driver
Best 60' time 1.33 with front tires; 1.34 with rear tire
10.06@135 1000' DA
ski_dwn_it is offline
Old 05-11-2008, 09:52 PM
INSANITY
INSANITY's Avatar
Car/year.................BLUEBERRY C4....1993
Motor type/size........434 small block 23' heads
Suspension.............. Carroll's Rods&Racecraft bolt in Solid Rear
Tires......................M/T ET Drags 28" 11.5-15
Approx. raceweight...3300lbs
Transmission type.....T350
DA if known.............3300'
Track.....................Lebanon Valley Dragway
ET and mph.............9.88@138MPH
INSANITY is offline
Old 05-11-2008, 09:54 PM
GeorgeZNJ
Support Corvetteforum!
GeorgeZNJ's Avatar
St. Jude Donor '08-'09
I'm posting this for a member who was/is banned for life, Ed, the C6DVL.
Driver-Doug@ECS
Et/MPH- 10.84@128.5
Car--08 C6 coupe
Motor-ECS Cam only LS3
Suspension--stock
Tires--Dr's
Weight--???
Trans--stock manual
track--ATCO
GeorgeZNJ is offline
Old 05-11-2008, 10:21 PM
Donny Brass
Donny Brass's Avatar
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
I can be on the list until there are 31 cars on it:
Car/year.................Milano Maroon 1966 Convert
Motor type/size........327 cid small block
Suspension..............General Motors finest stock parts
Tires......................F70 15 Firestone bias ply
Approx. raceweight...3250 lbs
Transmission type.....Muncie M21
DA if known.............1400'
Track.....................Mid Michigan Motorplex
ET and mph.............13.47 @ 104.02
Donny Brass is offline
Old 05-12-2008, 07:33 AM
Allthrottleandsomebottle
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
1997 Corvette Coupe
417 NA
Bone stock F45
MT ET Street radial 275/40/17 on OEM Magnesium wheels
3680 at the line
Rossler stage II 4L60E, fuddle 3800, 3.73
full exhaust
Richmond, VA.
See da slip, 10.82@125.14
~DA -1000
http://forums.corvetteforum.com/phot...7_pics0003.jpg
Not the fastest.........but pretty good for what it is
Allthrottleandsomebottle is offline
Old 05-12-2008, 10:46 AM
98NYFINESTVETTE
98NYFINESTVETTE's Avatar
Location: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Corvette Pace Car (Easter Egg) - 1998
Engine - 346
Suspension - Stock
Tires - Front/Stock, Rear/Nittos 275/40/17
Race Weight w/Driver 3640lbs
Transmission - Automatic
DA - 1,067
Track - Englishtown, NJ
Best Et - 10.78 @ 124.69 w/ throttle stop and on the brakes
98NYFINESTVETTE is offline
Old 05-12-2008, 03:58 PM
red79vette454
red79vette454's Avatar
My fastest N/A pass to date on Corvette IRS suspension.
Car/year................1979 Coupe
Motor type/size.......BBC/ 565 CID/ BMF heads
Suspension.............12 bolt IRS 3.73 gears
Tires......................15X10.5 Goodyear
Raceweight.............3400 lbs.
Transmission............TH 400/ATI 9" converter
DA if known.............2350'
Track.....................Thompson Drag Raceway
ET and MPH.............9.19 ET @ 148 MPH
red79vette454 is offline
Old 05-12-2008, 04:47 PM
  #33
vetteman9368
vetteman9368's Avatar
Location: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Originally Posted by red79vette454
Fastest N/A pass to date on Corvette IRS suspension.
are you claiming to be the fastest IRS C3?
vetteman9368 is offline
Old 05-12-2008, 04:50 PM
  #34
chaase
chaase's Avatar
St. Jude Donor '12
Car/year: 2003 Corvette Convertible
Motor type/size: 346 w/HC, gears and converter
Suspension: Stock IRS
Tires: MT ET Street Radials
Approx. raceweight: 3500lbs
Transmission type: A4
DA if known: -1000.0
Track: Englishtown
ET and mph: 11.584@117.7 mph
chaase is offline
Old 05-12-2008, 05:27 PM
  #35
red79vette454
Sorry! Corrected to say "My fastest N/A pass on IRS".
BTW: do you know the fastest N/A pass in an IRS C3 Vette?
Old 05-12-2008, 05:53 PM
  #36
GrandSportC3
Your 9.19 might be the fastest naturally aspirated pass on a C3 I.R.S. car.. However, Greg Eaton ran 8.50's @ 161, so he does have the fastest I.R.S. C3 that I know of.
Old 05-12-2008, 06:36 PM
  #37
cyclerage23
cyclerage23's Avatar
Default 10.43 @ 133
Car/year.......................1999 FRC (RIP )
Motor type/size..............LS2-402 n/a
Suspension....................Stock C5 w/bilstein shocks
Tires............................CCW Drag pack
Approx. raceweight.........+/- 3200 witn me it
Transmission type...........RPM M6
DA if known...................somebody knew, but not me.
Track...........................Atco
ET and mph...................10.43@133
cyclerage23 is offline
To The N/A Corvette Fast List
Old 05-12-2008, 06:43 PM
  #38
vetteman9368
St. Jude Donor '08
i think greg has been in the high 8.90's on motor
Old 05-12-2008, 06:44 PM
  #39
GrandSportC3
Well, he e-mailed me when he ran 9.24 on engine which was his best so far.. That has been only a couple of weeks ago..
His car and dedication to I.R.S. racing has been a great inspiration for me to try to push the I.R.S. as far as possible..
Old 05-12-2008, 06:54 PM
  #40
vetteman9368
St. Jude Donor '08
then I have him confused with someone else but i could swear someone has been in the 8's on motor
Quick Reply: The N/A Corvette Fast List
