Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
The N/A Corvette Fast List
Old 05-12-2008, 07:04 PM
  #41
GrandSportC3
GrandSportC3's Avatar
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by vetteman9368
then I have him confused with someone else but i could swear someone has been in the 8's on motor
His forum name is 2000-A4
Here is his site..
http://home.earthlink.net/~geaton/
Here is his last post confirming his best na ET..
http://forums.corvetteforum.com/show...8&postcount=32
GrandSportC3 is offline
Old 05-12-2008, 07:27 PM
  #42
2000-A4
2000-A4's Avatar
Default Irs
The 9.24 @ 150.35 (5.91 @ 119.21 - 1/8) is the fastest mine has been on motor and 8.58 is the fastest on nitrous. It has been fast enough in the 1/8 to run a high 8.49 or low 8.50. I believe it could run some teens on motor late or early in the year at HRP in Houston, TX.
I’m working on making it run on 275 DR for a local class and I hope to make it run as fast or faster.
2000-A4 is offline
Old 05-12-2008, 08:56 PM
  #43
Hurri
Hurri's Avatar
Default Well, mite as well, maybe it will help with a sponsor
1968 Coupe
427/390 HP
Stock Q-jet
Stock lift cam
Stock heads
Stock intake
.065 over bore Stock compression ratio Pistons
A set of headers that looks like something out of Fred Stanford's yard
TH350
Camaro 12 bolt rear-end
9" Inch slick
3512 lbs with driver
Runs NHRA C/SA
10.78@124.30 *More left I'm sure*
Hurri is offline
Old 05-12-2008, 09:57 PM
  #44
vetteman9368
vetteman9368's Avatar
Location: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
So I talked a friend of mine into coming over and joining. He has a fast car, and a very impressive racing background. I'm sure he will be along shortly
vetteman9368 is offline
Old 05-12-2008, 10:03 PM
  #45
STEALTH 99 C5
STEALTH 99 C5's Avatar
Rob , With the amount of replies already , it looks like you should classify the times by generation . Here's my timeslip for my Cartek 441 set up , best ET 9.951 at 137.81
STEALTH 99 C5 is offline
Old 05-12-2008, 10:08 PM
  #46
Paul_Z06
Paul_Z06's Avatar
11.37 @ 119. 2002 Z06 stock motor. Vararam, headers, ET drag pack.
Paul_Z06 is offline
Old 05-12-2008, 10:53 PM
  #47
SS/AA324
3rd Gear
SS/AA324's Avatar
Hello....i was told about this thread by vetteman9368 so here i am. My name is Brandon Wilkinson and I drive a 69 427/430hp car in SS/AA. I have been 8.77@150.05mph. That was at 3075lbs.
SS/AA324 is offline
Old 05-12-2008, 10:55 PM
  #48
Paul_Z06
Paul_Z06's Avatar
Niiiiiiiiiiiiiiiiice! Welcome. Your car for sale?
Paul_Z06 is offline
Old 05-12-2008, 11:01 PM
  #49
vetteman9368
St. Jude Donor '08
not sure about brandon's car but this one is
http://www.racingjunk.com/post/11089...per-Stock.html
Its a nice car, VERY clean
Old 05-12-2008, 11:04 PM
  #50
SS/AA324
3rd Gear
SS/AA324's Avatar
Thanks, and sorry...not for sale. Still trying to figure out how to go faster The car Chad just posted is probably one of the CLEANEST superstock cars in the country. Very nice.
SS/AA324 is offline
Old 05-12-2008, 11:05 PM
  #51
INSANITY
INSANITY's Avatar
That is one bad *** stocker.......
INSANITY is offline
Old 05-12-2008, 11:06 PM
  #52
vetteman9368
St. Jude Donor '08
superstocker
Old 05-12-2008, 11:27 PM
  #53
Corvette Chris
Corvette Chris's Avatar
Wow.
Love a race car still having a full interior
Corvette Chris is offline
Old 05-13-2008, 07:39 AM
  #54
GrandSportC3
8.77 - WOW!!
Old 05-13-2008, 07:52 AM
  #55
0Rick@Moroso Performance
Former Vendor
Rick@Moroso Performance's Avatar
Location: Moroso Performance, Guilford, CT, 203-453-6571
Car/year...................1961
Motor type/size..........SBC 363 c.i.
Suspension................4-link, coil-overs, 9 inch rear 5.83 gears
Tires........................MT 31 x 10.5 Ws
Approx. raceweight.....2980 lbs.
Transmission type.......Torque Flite, 2.18 first gear
DA if known...............1452
Track.......................No Problem in LA
ET and mph...............8.658 @ 151.82 mph
This is a pick of the acual pass. 1.209 60 foot!
Rick@Moroso Performance is offline
Old 05-13-2008, 09:32 AM
  #56
2000-A4
2000-A4's Avatar
Car/year…………………………………1970
Motor type/size……………………..427c.i. SBC with 23 degree Dart 220’s
Suspension…………………………….IRS with 12 bolt spool and 4.10 gear
Tires……………………………………….MT 28 X 10.5 slicks
Approx. race weight………………3100 pounds
Transmission type…………………Glide with 1.80 low gear
DA if known……………………………N/A
Track………………………………………San Antonio, Texas at Pinks All Out 3/8/08
ET and mph……………………………9.24 @ 150.35
2000-A4 is offline
Old 05-13-2008, 09:39 AM
  #57
GrandSportC3
Tires........................MT 10.5 Ws
DA if known...............Can't find log book, around 1300 I think, I'll find it and the time slip
ET and mph...............8.656 @ 152 mph
This is a pick of the acual pass. 1.20 60 foot!
That's a incredible ET for the mph..
What kind of heads?? I'd bet my house that it's not 23 degree heads
To The N/A Corvette Fast List
Old 05-13-2008, 10:06 AM
  #58
Former Vendor
The heads are 13 degree, All Pro.
Old 05-13-2008, 10:11 AM
  #59
2000-A4
2000-A4's Avatar
This has always been one of my favorite cars from the NMCA Hot Street days, especially with the hub caps. To me, Rick and his guys always took special care of this car and respect its history. It’s definitely something to see if you have the opportunity.
2000-A4 is offline
Old 05-13-2008, 12:33 PM
  #60
supercoupe01
supercoupe01's Avatar
Here is my run from 2006. It might last a day or so.
2001 Corvette Coupe
ECS 447 cu in.
stock with Z51 option
MT ET Street with Skinnies
Fully loaded coupe with roll bar
MN6 with 3.73 gears
DA probably around zero + or -
Cecil County Dragway 3/11/2006
10.708 133.63
supercoupe01 is offline
Quick Reply: The N/A Corvette Fast List
