Uneven rear deck bonding area
I am getting the car ready to spray with epoxy primer and ran a long board sander across the rear deck to find all the nicked areas I put on it during paint removal. In the process a strip showed up all the way across the deck, this is the area where the deck is bonded to the inner tub. What are people doing about this area? Leave it be and just move on? I really don't want to smear VPA all over the rear deck to smooth this out if it is not going to help much.
Knowing you do not want to read it. That is precisely what I do. I apply VPA (Vette Panel Adhesive) across the entire deck and block my A$$ off. IT IS one of the BIGGEST pains in my backside...but when I am done that panel is flat ( or at least you are not feeling the 'hump') and it actually is much stronger and no so flexible when you press on it with your finger and mild pressure.
On some Corvettes (pre-SMC)...I remove the fuel tank and actually laminate sheet of mat to the underside of this panel to give it a bit more strength due to it being so weak...in my opinion. THEN do the VPA process.
My mentality on this as follows. If I am getting the car straight and looking good....why would I paint on urethane bumper covers that have buckles/warps in them...WELL...I would not....SO...why would I do all of the other things I do to the body to get it RIGHT and leave this area.
DUB
DUB
For some reason, I knew that was going to be the answer.
I guess I will get another can of VPA headed my way. It will probably not be that big of a deal, as you can see I left plenty of nicks that need to be filled anyway.
Another question: I guess the possibility of the VPA cracking or popping loose from the rear deck flexing is not an issue to be worried about?
[QUOTE=Texas70;1587910292
Another question: I guess the possibility of the VPA cracking or popping loose from the rear deck flexing is not an issue to be worried about?[/QUOTE]
YES...because I am NOT THERE to see how you PREP the area. That was a 'trick question' wasn't it????
I do not know how you mix, apply the VPA....if you allow air bubbles to be in it due to not correctly mixing it....IF you try to apply a super thick layer at one time or not.
I can easily get the VPA to a 1/4" and not have any worries.
AND...think about it. IF the VPA were to crack.....in order to make it crack...don't you think that the original fiberglass would not have also cracked under the same scenario WITHOUT any VPA on it????
I myself have no worries...and in numerous cases where I use VPA and do some of my 'tricks'...the VPA actually saved the area due to being so stout. Yes it cracked....but TRUST ME...without it...it would have been obliterated. AND In some cases...nothing happened at all...but WOULD HAVE if it had no VPA in that 'trick' spot.
Here is a tip....but you have to think a bout it. When you go to apply the VPA to achieve a good flat spread. Think about what you would SEE when workers perform that final finish a concrete driveway. Think about it.
DUB
DUB
Back deck uneven.
I have the same issue with my back deck. Is this common, and if left alone would probably look pretty noticeable with new paint? I do recall taking a lot of filler/primer off this area. It is almost like my gas cap door area is on a island slopping all around and down to the spoiler.
Before, you can see a line running in the middle from the gas cap to spoiler:
PO "fix" that I removed:
Now:
I guess I'll need to VPA the whole area? Still deciding on whether to drop the tank. With the in tank fuel pump and regulator I don't need any issue that were already tackled showing up again.
Any further advice. Thanks.
Now:
I have dropped the fuel tank...prepped and laminated fiberglass mat and resin to the underside of this panel....then filled the top surface with VPA....which I can tell you...is NO EASY TASK!!!!! This ares with VPA is a serious undertaking....NOT for those who quit things when the going gets rough....because....seriously....this is no FUN.
The one blessing is that when the panel gets some rigidity to it...it makes the blocking a bit easier...but that in itself to still a lot of work. I have done about a half dozen or so.....and DREAD having to do it if one comes in all screwed up and this panels is buckled/warped.
DUB
DUB
DUB
DUB
Is this panel supposed to be completely flat, or slope after the gas cap?
I am sure that when you run your hand across it from rear to the front...that you can feel the hump...and this hump is where the inner 'tub' for the interior is bonded. AND when you lightly press on the fiberglass to the left or right of the fuel door opening...and half way to the 'spoiler'...it moves very easily.
DUB
I can only imagine that it was 'supposed to be' flat...and it sunk over time.
DUB
DUB
Also, maybe drop the tank. Thanks.
That is correct. It also had a lot of boxes and crap stacked on it over the years from the PO. As you can see in the blue and white PO photo, it did not take a ton of filler to make it 'flat', so I think that it would be somewhat minimal to VPA the surface around the fuel door, and block it smooth until I can get a straight edge to lay flat all over. Sound reasonable?
DUB
DUB
DUB
Question please and just to double check, when you say VPA or Vette Panel Adhesive, this is it?
http://www.evercoat.com/productDetail.aspx?pID=40
as in evercoat 870 or 880 Vette Panel Adhesive?
Thanks!
Thanks!
Thanks!
IF you go to buy some...CONTACT Evercoat and get their method of date coding their product.....so when you go to buy some...you are not buying a gallon that is ten years old and then write that the stuff is crap. Some forum members have PM'd me letting me know that is what would have happened....and got the paint supply shop to get fresh product in.
DUB
Thanks for the info and advice!
YES...Made by EVERCOAT....part number 870 (quart)...880 (gallon)
YES...there is a very slight raised ridge..so to speak in the middle of the fuel door area....BUT not a sunken area to the left and right of the fuel door.
DUB
DUB
Does this hump look normal as its supposed to.
So this is my hump, and need to know if this is normal. It seems to be consistent. Don't want to flatten it if it's supposed to be there.
Thanks.
The side to side 'check' you did with the level is correct. But I still fix that somewhat...and still have the center 'high' peak line...so-to speak.
BUT...the front to rear one with the angle iron is the one that I 'fix'. I do not like running my hand up from the 'spoiler' area...and when I get to right past the fuel door opening...I feel a bad hump or low spot. That is where I fix it.
But that is just me. This area can be filled and still give the 'look'...and also makes this panel stronger and not so weak when pressed on. That is open to personal interpretation...and for me....I do not like weak panels that are easy to move.
DUB
DUB
I hope this isn't a hijack but I found this interesting because I'm getting ready to bond my rear deck in place. I'm not really sure how much adhesive to install under the rear deck bonding strip to minimize the amount of filler (if any) needed above the rear deck bonding strip.
My plan at this point is to dry fit the rear deck, note the distance between the underside of the deck and bonding strip and then write note at different stations on the bonding strip to tell me how much adhesive to build up.
Personally, I don't think I am going to do a large skim on the deck area. It probably didn't have it from the factory but I do understand owners doing resto mods trying to get this area better.
Kevin
Kevin
Kevin
Kevin
Sorry, don't have a pic of the glass. I put undercoating on it, so you couldn't see it anyway. Upside down glass is a PITA.
DUB
