It's all about that base
Most panels covered with 3. I had to deal with some issues, those panels took 4. I cut the base with the RM60 reducer 1-1. I still have to do the door jams that are on the door. It took so far 3 qts. I used my new (to me) Tekna Pro Lite. Amazing the difference a good gun makes. Thanks for giving me the ok on the RM.
No I think even after 1 other coat after I posted, it was light on the inside ridge of the drivers side top surround. Then I thought I saw some "maybes" so I mixed a qt RTS and gave it all another go around. I have just enough mixed up for the hood and when my wife gets home, we'll put the hood back and I'll give that a shot to. It'll leave me with + half qt of paint left for the jams.
Are you temporarily mounting the doors and blowing a coat on them to get them to blend in and match with the quarters and fenders??? The reason is that painting the car with them off and getting the jambs on the main body is fine. BUT...if you do not have the doors on the car....WHEN you spray your final coat. THERE IS a chance that the doors will not match the body perfectly....due to metallic structure and coverage issues . Solid colors are often times not problem so much...but metallics can come back and get you when you pull it outside and look at it from a short distance (50-100 ft) and see that the doors are off in color saturation. And due to this color being a metallic. There are three angles that it needs to be viewed at. looking straight at it.....then at a 45 degree angle.....then down the side. And the BEST ( and worst) type of light is a overcast day. THAT will let you know for a FACT that you got it RIGHT. A sunny day is too bright. A person can easily get blinded. Overcast days....they can be my NEMESIS.
And you also wan tot manually hold the headlight bucket where it goes with one hand and blow paint on it and make sure that it is blended out also.
YES...I like the RM also....it works very much like NEXA.....not exactly the same but some darn good paint! Just did a spot repair for a black 63 SWC and it turned out flawless.
LOOKING VERY GOOD TWINRAY!!!!!
DUB
DUB
DUB
DUB
