54 vette body work
54 vette body work
Okay I need some help from the experts. I have a couple things that need to be fixed. There between the door and the rear wheels on both sides and are completely separated. I also need to fix the rear panel at the bumper corner. this is not completely separated but needs to be fixed so any suggestions would be appreciated. The body has been taken down to bare glass with a baking soda blast and a good wash with soap and water. What materials do you recommend I use for regluing the seam
and filling the gaps.
I need a GOOD clear photo of the crack on the quarter panel from the INSIDE.
Just by looking at photo's sometimes it is REALLY HARD to tell a person how to fix a crack...so...I have to be able to see what you see. So photos of what it looks from the inside of the panel if possible is very helpful.
AND....where then is panel separation....knowing how easy or hard it is to separate the panels is also helpful and if a tool can be inserted and spread the seam a part and a good description of how the two parts that are separated ..and how they can be joined.
Often times...there are flanges at the end of panels that allow then to be bonded together to give the joint strength. Much like putting two pieces of angle iron together. BUT...if the joint split or cracked and still allowed the flanges to be bonded...but the panel tore or cracked right above the bend in the flange...that...changes the repair entirely.
And then there are bonding strips which is a completed different way of butting two panels together.
SO...this is why like I wrote I need to see what you *** and ANY information is helpful.
DUB
DUB
Thanks for the response. Here are a few more photos you requested. It does appear that the lower panel section has partially torn off from the flange. I added a photo where the red area shows the panel tear from the inside. The blue clouded area is also separated from the interior wheel well panel. No tear but still needs to be re-glued.
THANK YOU for the added photos. It aids me in having more pieces of the 'Jeopardy' puzzle turned over so I can plot a solution.
Question(s).
Knowing that this body has had a few areas that were repaired previously. HOW CONCERNED are you in how these repairs are accomplished???
Are you going for PERFECT TOP FLIGHT/NCRS stuff.
OR....Want a solid structural repair???
Kinda need to know.
ALSO....if you could,,,it the other side is fine on the quarter...can you post photos of the outside and inside of it like you did the left side??? ESPECIALLY if you want the repairs made so they are really undetectable.
DUB
Question(s).
Kinda need to know.
DUB
Question(s).
Kinda need to know.
DUB
Question(s).
Kinda need to know.
DUB
OK......sent you a PM.
DUB
DUB
Received 1,436 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
I fix alot of these 53/54's
Originally the seam was riveted and bonded together
I used a product called Glasin
You can bond the rocker and surround back together
Re-rivet if you want the original look
The wheel houses always come loose from the surround
I pry the surround away slightly and pack the seam with Glasin
Glasin is a fiberglass mending material
I can send you some to try.
It is a very easy repair
