Baseline passes before the A&A kit goes on.
St. Jude Donor '12-'13
Went out to Great Lakes Dragway yesterday.......
Car currently has the following mods :
Breathless Performance Products Vortex Rammer Cold Air System
Ported Throttle Body
LS6 Intake
Texas Speed & Performance Long Tubes & Off Road mid pipes
Corsa Indy Pace Car Exhaust
Tuned at 337 RWHP / 349 RWTQ.
Pass was made on MT ET Street drag radial @ 20 psi ( 275/40/17 )
60' : 1.963
330 : 5.477
1/8 : 8.325
MPH : 86.93
1000 : 10.775
1/4 : 12.853
MPH : 108.85
I was hoping for a 12.6 but I just couldn't get outta the 1.9 60'
LS6 Intake
60' : 1.963
330 : 5.477
1/8 : 8.325
MPH : 86.93
1000 : 10.775
1/4 : 12.853
MPH : 108.85
LS6 Intake
60' : 1.963
330 : 5.477
1/8 : 8.325
MPH : 86.93
1000 : 10.775
1/4 : 12.853
MPH : 108.85
LS6 Intake
60' : 1.963
330 : 5.477
1/8 : 8.325
MPH : 86.93
1000 : 10.775
1/4 : 12.853
MPH : 108.85
good times, lower 60' would put the car in the low 12's, the blower should change things alot, providing you can hook up, either way the trap mph will give you good info.
looking forward to the results, I have been thinking about this kit just curious to track results!
LS6 Intake
60' : 1.963
330 : 5.477
1/8 : 8.325
MPH : 86.93
1000 : 10.775
1/4 : 12.853
MPH : 108.85
LS6 Intake
60' : 1.963
330 : 5.477
1/8 : 8.325
MPH : 86.93
1000 : 10.775
1/4 : 12.853
MPH : 108.85
what gears you running. if 3.15 you should have at least 3.42 instead. get the 60 ft down that way those tires should hold but as you get fASTER YOULL ALWAYS HAVE TO PLAY AROUND WITH THE PRESSURE
Yup, this is where I'm at so far......
All passes were made on MT ET Street drag radial @ 20 psi ( 275/40/17 )
Pre-Blower
60' : 1.963
1/4 : 12.853
MPH : 108.85
Post Blower
60' : 1.759
1/4 : 11.635
MPH : 118.90
Headed back to the track when it's cooler....keep ya posted.
Pre-Blower
60' : 1.963
1/4 : 12.853
MPH : 108.85
Post Blower
60' : 1.759
1/4 : 11.635
MPH : 118.90
Why don't you try and lower tire pressure a couple of pounds. I know I couldn't cut a good time till I got them in the 17-18 range, and I am using the same tire as you.
As a pure bolt on car it made 337/349, post A&A it made 512/463.
460 makes sense with the trap speed.....but the dyno said otherwise. My experience says the MPH don't lie.
I beat a C6 ZR1 at the track one day, but that was because he had no traction early. Your 60' times indicate a lack of traction as they should be lower. That size/compound tire is not optimal for that hp level. My last recollection was that DR's were only good traction until about 450rwhp or so.
I was extrapolating rwhp based on the difference between the two runs, which is approximately 120hp, and average gains of a S/C kit. There are a lot of variables and higher hp cars can end up being slower than expected due to traction issues.
I'm planning on heading back out to the track on Monday....I'll keep ya posted.
Please do, have fun and be safe out there.
Received 1,763 Likes
ttt
Looks good for what it is man other than the 60 ft. But for sure in a M/T D/R you have to much air in them. On the set up weight of car and all that crap,but pull ait to 18 psi and next run go to 17 psi. Then ajust from that.... Robert
