15" Wheels Only Picture Thread
Old 02-04-2016, 03:12 PM
Richard Daugird
Richard Daugird's Avatar
Default 15" Wheels Only Picture Thread
I did a search and didn't find anything specifically for 15". I have a set of 15x8.5 and 15x10 aluminum slots. I want something that will fill the wheelwells nicely, and I don't want the rear tires shorter that the front. I am wondering what size tires guys are using on big and littles in 15". Pictures?
Old 02-04-2016, 03:23 PM
Peterbuilt
Peterbuilt's Avatar
Received 1,246 Likes on 966 Posts
All my Western Wheels are 15" X 8.5".
I have 235 70 15 up front and 255 60 15 in the rear.
96 lt-4 (02-07-2016)
Old 02-04-2016, 03:32 PM
a striper
a striper's Avatar
15 x 8 and 15 x 10, 245-60-15 and 295-50-15. I notched the trailing arms and it's a tight fit.
The following 2 users liked this post by a striper:
Alex66 (11-18-2021), rogernison (02-05-2016)
Old 02-04-2016, 03:58 PM
7t9l82
7t9l82's Avatar
I have 15x8.5 all around 255 60 15 on the front and 275 60 15 drag radials in the back.
Old 02-04-2016, 04:12 PM
Richard Daugird
Are those tires about the same height? If so, that is probably the sizes I need. Got a side profile shot?
Old 02-04-2016, 04:17 PM
a striper
a striper's Avatar
IIRC the fronts are a fraction smaller diameter.
Alex66 (11-18-2021)
Old 02-04-2016, 04:20 PM
Richard Daugird
That's about perfect! I love the 200 s Daisy wheels as well. Stock ride height?
a striper (02-05-2016)
Old 02-04-2016, 04:28 PM
a striper
a striper's Avatar
I added 550# front springs and removed a bit a couple of times till the front as "there that looks right". I added lowering bolts out back and set it "there that looks right". The stock width rear spring would not work with this combination. I think that it is down a bit but don't have a reference to say how it would compare to stock. With the back up just a bit the tires never touched the chassis. Like this or even a bit lower I get some "shiny spots" on the frame but the tires must just kiss it because they have almost no indication of touching.
Old 02-04-2016, 04:47 PM
Richard Daugird
Those are the exact mods I plan for my '74. 10" bolts? Does your exhaust pass under the rear diff, and does it drag?
Old 02-04-2016, 05:00 PM
a striper
a striper's Avatar
I don't remember the size (I did this ten years ago) but they were just the next size longer than stock.
Keep in mind this rear set up is very tight. With the rear spring removed I had about .06" clearance to the fender lips at full compression. I am surprised that there has never been signs of touching there. Also, not every companies 295-50-15 will be the same size. I have seen a lot of variation in tires listed as the smae size from different makes. Based on other sizes I've used it looks like Cooper Cobras might be a bit narrower. The could be a good thing. With mine if the tires were any larger than my BFGs there could be problems. Any difference side to side with the vehicle might matter wit this set up too. A 1/4" offset of the body is no big deal with narrower tires but here it would matter.
I made up the exhaust using mandrel bends form 2 1/2" pieces. I have about 3/4" clearance to the spring near the center. It has hit things over the years but similar to any other low vehicle. I'd worry heat into the spring if it were on a road course for 30 minutes of high power output but street use seems fine. Over the years I have tightened the bolts twice to restore the ride height. I don't know if the slow settling is normal for a fiberglass spring or is a reaction to heat.
Good luck with your '74. Long live the dual exhaust Sharks!
Old 02-04-2016, 05:06 PM
Richard Daugird
Do your pipes drag?
Old 02-04-2016, 05:09 PM
a striper
a striper's Avatar
Do your pipes drag?
I'll see if I can get an idea of the ground clearance.
Old 02-04-2016, 05:48 PM
Richard Daugird
Thanks for all the info. I used to deliver pizza 10-12 hours a day on terrible roads in an extremely low mini truck back in the 80s, so I can probably manage not to tear this thing up if I have a few inches cleareance. You can get away with low on the axles centerline much easier than in the middle of the car.
Old 02-04-2016, 06:10 PM
gjohnson
gjohnson's Avatar
Do you have any pics that show exactly how you notched the trailing arms and what is the back spacing on the 15x10's?
Old 02-04-2016, 08:05 PM
Mod75
Mod75's Avatar
Finalist 2021 C3 of the Year - Modified
275/60/15 in back
255/60/15 up front.
Old 02-04-2016, 08:24 PM
a striper
a striper's Avatar
Do your pipes drag?
A two by four will just slip under the low spot.
Old 02-04-2016, 08:37 PM
a striper
a striper's Avatar
Since the bushings and alignment were good I notched them while on the car. The reinforcement extends a couple of inches beyond the opening. I welded it as far as I could thought the opening plus plug welds on the back side. And of course the parking brake cable has to be moved.
Here's the BS info https://www.corvetteforum.com/forums...post1591003218
gjohnson (02-05-2016), Strokemyaxe (02-06-2016)
To 15" Wheels Only Picture Thread
Old 02-04-2016, 08:48 PM
Calo69
Calo69's Avatar
St. Jude Donor '15-'16, '18
D
235/70 rear<br/>235/60 front
The following 2 users liked this post by Calo69:
Alex66 (04-26-2020), frankcfalco (09-23-2021)
Old 02-04-2016, 09:02 PM
trw
trw's Avatar
245x60 Front and 255x60 Rear.
Old 02-04-2016, 10:56 PM
ykf7b0
ykf7b0's Avatar
Pacer 15x8 wheels with 255 60 15 Cooper Cobras all way around.
Quick Reply: 15" Wheels Only Picture Thread
