Brake booster
Brake booster
Hey Guys,
I started noticing a vacuum sound every time I press on my brake peddle is this normal? I've learned to live with a spongy brake peddle, but I don't want to add to an already crummy braking system with a bad booster.
Thanks,
Al
Thanks,
Al
I have been bleeding, and bleeding these brakes with no success. I upgraded the front calipers to Wilwood calipers mistakenly thinking that it would help and it didn't. The brakes will work but I am not able to lock the wheels when I stand on them.
I bought my '72 in '95 and in all them years early on, I have tried all sorts of solutions for that soft pillow we call brakes.....hit the pedal and it goes ehhhh, squisssssh to the firewall, and sharkey MAY feel like stopping.....I went to over bore sized truck m/cyl, took out that silly brake fail switch, commonly called a proportioning valve, which it is NOT and put in a simple splitter to the front brakes, and the line to the forward port on the m/cyl......rear brakes of course already had a T splitter so nothing done there.....
and still the brakes sucked, along with vacuum......
SO many years ago I picked up on the Hydroboost brake booster that runs off the power steering pump, installed it, and hit the brakes, sharkey stood on her nose and MY nose went into the wheel.....
takes a bit getting used to.....only 2-3 inches to lockup which is hard as a rock......not that soft feeling that goes to the firewall like a limp sister......
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I welcome any correction here, but it's my understanding that if you hear a hissing sound when applying the brakes, it's generally due to the disintegration of the foam filter/silencer at the brake pedal rod going into the booster.
Test the brake booster. Connect a hand vacuum pump and see if it holds. Similar to this thread. ( I tested the unit outside of the car ) but you can do a similar test while on the car.
https://www.corvetteforum.com/forums...f-the-car.html
After this tests ok. Did you replace the pads when you where bleeding the brakes. If the pads have wear then it is very possible to trap air in the caliper pistons and the only way to remove this air is by pushing the piston in. I usually shim the pads to force them to completely push the pistons into the caliper. I also use my air compressor connected to the master cylinder and set to 10-15 PSI to pressurize the brake lines to bleed.
"live with spongy brake"
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
I knew when my brake booster went bad. After I turned off the engine, I pulled the check valve from the front of the booster and didn't hear a hiss of rushing air into the booster. When I replaced the booster, I could pull the check valve a day after shutting down the car and would hear a hiss.
Bad booster. Seals are old/dried/shrunk and not sealing well.
Now, that will improve the power-assist function of the brakes...but it will NOT tighten-up the brake pedal problem. That is due to air in the system or very old brake fluid which as ingested some water into it over the years. Also, if you have any OLD rubber brake hoses on ANY of your calipers, you NEED to replace them. The rubber on the inside of those hoses deteriorates and tends to block off fluid flow. They can cause continuous partial apply of that brake set [and constantly build heat!] or cause spongy feel in the pedal because they tend to 'bulge' under pressure.
I'll followup with an updated post as I continue to swap out parts.
Get some advice from a junkyard as to what vehicles a HydroBoost comes off of......or if it's a U pullit yard....bring your tool set and start lookin'.....
Years ago, my brake pedal was spongy, I bled it till there was no air, I eventually determined the reaction disc in the booster was soft and causing it. Instead of replacing the booster, which would have fixed it, I changed over to the hydro boost without opening a brake line, I instantly had a good hard pedal. I don't see ever needing better brakes than what it has now, I can lock them up anytime I want.
Royal Canadian Navy
My '72 passed that test several times, just says the booster is good, basically......not that it's good enough.....
Correct and I also agree with 7T1vette. But if you have a bad booster with the symptons I described, there's a good chance you have a vacuum leak also i.e. booster can't maintain a vacuum. So when you hit the brakes hard at speed, your idle drops and maybe your vacuum. Not good. As for hydroboost, it's an option that's just as effective as a properly functioning oem brake system. That's why I haven't converted - no need.
believe me, you will be FAR happier for the conversion....
