WELD S77 18" question / Urgent
Hi All
I wishing you all the very best in 2016!
I'm little bit confused and don't know which size is the best for my narrow Vette! 18x10 69mm or 18x10.5 75mm?? I don't wanna the tires goes out of the fenders.
Well, "narrow Vette" must be a C6 or C7.
So:
285 tire at 65mm rear wheel offset
295 tire at 70mm rear wheel offset
305 tire at 75mm rear wheel offset
315 tire at 79mm rear wheel offset
Then each tire size is on its spec wheel width
So:
S77 medium pad 18x10 69mm and the tire will be M/T 305/35R18
What do you think?
A 305/35-18 on the 18 x 10.5 75mm wheel would be okay.
The reason is that the wider wheel doesn't effect the top of the tire very much but wheel offset moves the top of the tire by the amount of the offset difference.
Here's another rear wheel:
Oz Alleggerita, 18 x 11, 75mm
Here's the track and autocross setup:
C7 front, 18 x 10.5, 58mm, C5 Z06 rear wheel, 315/30-18 Rival S tire
C7 rear, 18 x 11, 75mm, Oz Alleggerita, 315/30-18 Rival S tire
Of course, the tire stagger is lost but the Rival S is not available in very many sizes. Also, that's a short rear tire.
Here's another setup:
Front, 19 x 10.5, 59mm Oz Superleggeria III wheel, 295/30-19 Pilot Sport Cup 2 tire
Rear, 19 x 11, 75mm, Oz Superleggeria III wheel, 315/30-19 Pilot Sport Cup 2 tire
Or go to the Weld web site and order CCW two-piece wheels
