Zr1 front splitter
Zr1 front splitter
I just got a zr1 spoiler to go on my 2007 c6 base model and was wondering how to install it. It seems like its not wide enough. I cant seem to find a video or instructions on how to install it.
For the front splitter I just lined up the ends with the front of the wheel openings on the fenders while supporting the center with a box. When the ends of the splitter are flush with the fender openings secure both ends with self tapping screws then raise the center of the splitter into position and secure that with a screw then work your way around from the center to each end with more screws.
Here's how it should look when mounted properly.
IIRC you have to buy a specific ZR1 clone splitter for the base model, as the front bumpers are different. Could this be the issue?
If you are in fact, asking about the splitter, the ZR1 splitter is not compatible with the base C6.
The next question is...is it a splitter as in the subect title or a spoiler as in the message body?
I know there's a difference. One will fit a base C6 and one won't.
It's actually a splitter. I was in the middle of messing with my spoiler while I was typing. But I bought this and in the description it says it was for base models. EVRose I'll try your idea and let you know. Thanks for the replys
