Sponsored by: Innova
Fuse Location
Old Jan 28, 2005 | 04:37 AM
ROD BROWN's Avatar
ROD BROWN
Default Fuse Location
i have a 99 Coupe with the 12 CD changer in the rear compartment.I tried to use it today and it wouldn't turn on.The radio works fine,but when I push the button on the radio to turn on the CD player nothing happens. This is the factory CD player installed at the factory Can anybody tell me where the CD fuse is located?
Old Jan 29, 2005 | 01:31 AM
bogus's Avatar
bogus
odd. make sure the cable is attached. I doubt there is a specific fuse just for the CD changer.
Changers are attached to head units by special multi-wire line level cables. There are wires for left/right, ground, power, memory and control data.
Old Jan 29, 2005 | 10:23 AM
ROD BROWN's Avatar
ROD BROWN
Default Found the problem
Thanks for the info.I found a loose wire.All is well again.I just assumed it was a fuse,but I was wrong.a little guidance goes a long way.Thanks again!---Rod
To Fuse Location
