PC Power Suppy to Car Amp Mod
I needed to run a car amp in the house to test some stuff so I did up a cheap power inverter using a PC power supply. It is much cheaper than buying one so I wrote up a quick and dirty howto.
Questions, comments? (Yeah I know I should do thumbnails, maybe later when I have a bit more time)
http://www.corvetteforum.net/c4/df/powersupply.htm
I usually use one of these guys
100/50/10 amp version. Since the overprotect current is rather slow, you can do all sorts of testing with these guys....Ive used them for about 15 years with great results. Best unregulated power supply you can buy off the shelf for under $50 bucks. Works great for powering amplifiers that require 10-20 amps. I used to mount a 110 volt muffin fan on them, to cool it off. I used to charge the Hydraulics in one of my old lowriders with these, so id get real hot. But they take abuse well.
and its great for recharging the batteries in your TV remote. I can usually get 1.5 years use out of 2 AA standard non-recharable batteries. Ok, im cheap sometimes.
It is harder to find these now-days, since the latest versions from Schumaker are the minimum current load sensing transistor switched verisons, where you cant overcurrent them at all. Whats the fun with no sparks?? I thought that I could go to walmart or Advance and pick one of these up for the rest of my life, I guess I didnt expect them to stop selling the old type.
snoopdan
If that doesn't convince you that it is putting out more than 1.5 amps feel free to just move onto the next thread.
I guess the power supply I was using was crappy. It couldnt keep up with a DVC L7 I have here at the house on a SAS 500 watt amp. I try to admit when im wrong.
Was your meter wired in series or parallel with the load? just wondering.
snoopdan
On a 500 Watt amp you would be pulling more than 40 amps, likely around 50. So yeah, the power supply would either barf or be severly underpowering the amp.
It is wired in series, that is the only way that you can see how much current is flowing through the circuit.
snoopdan
