Sponsored by: Innova
Amp Power Wire Through C4 Firewall ... Easy Route ??
Old Feb 19, 2005 | 08:54 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Amp Power Wire Through C4 Firewall ... Easy Route ??
I'll start with DAMN the search fuction. It hasn't worked right for over a year
Is there an easy route for an 8ga wire through the firewall ??
Old Feb 19, 2005 | 09:39 PM
snoopdan's Avatar
snoopdan
I own the exact same year as yours. I just shoved mine thru right behind the battery on the firewall...There already exists a grommet with other wires in there. I just fed it thru with a coat hanger first, and electrical taped my power wire onto the end and used it as a poor mans' fish tape.
Help any?
snoopdan
Old Feb 19, 2005 | 10:27 PM
AGENT 86's Avatar
AGENT 86
Help any?
snoopdan
Thanks, I'll look in the morning
Old Feb 20, 2005 | 01:13 AM
muddpile's Avatar
muddpile
Someone had slipped with a screwdriver or something once behind my battery and punched a hole. I just made the best out of a bad situation and enlarged the hole with a rasp to fit 4awg.
Old Feb 20, 2005 | 04:38 AM
snoopdan's Avatar
snoopdan
YOU BIZZATCH! see if I help YOU anymore !
I ran down the damn batteries in the cam
snoopdan
Old Feb 20, 2005 | 03:31 PM
vetterlatethannever's Avatar
vetterlatethannever
snoopdan
Except I drilled a hole because I ran 4 gauge power and ground to the back in my previous C4.
Old Feb 20, 2005 | 05:27 PM
OrthoAggie's Avatar
OrthoAggie
i just reran my power wire and replaced it with 1/0 and i ran it through the panel behind the pedals, it is lower than the battery but it was the easiest way i could do it without touching the factory wiring cause the 1/0 is not small wire...
Old Feb 21, 2005 | 08:11 AM
AGENT 86's Avatar
AGENT 86
Thanks everyone
To Amp Power Wire Through C4 Firewall ... Easy Route ??
