Sponsored by: Innova
Sub Location
Old Feb 21, 2005 | 09:05 AM
whiterg's Avatar
whiterg
Default Sub Location
I'm interested in adding a sub to my existing Bose system and the question I have is where.
I've got an 04 Vert and I've installed heavy duty Lloyds trunk mats and a partition. Adding the partition improved the stereo greatly but I like to still add a little punch from a sub. With the partition installed I'm concerned that putting a sub in the back would get blocked out.
Anyone have any ideas on a different location. I'm thinking about a single 8" or 10", not looking to beat up the neighborhood, just want to add some power at the low freq.
Old Feb 21, 2005 | 09:54 AM
PYRO1's Avatar
PYRO1
Cruise-In VII Veteran
Check on a stealth box at http://www.subthump.com/vette.htm
Steve at subthump is a great guy!
I was thinking of adding a sub to the Bose system, but I decided to do the whole system.
Old Feb 21, 2005 | 02:32 PM
Postergeist's Avatar
Postergeist
I've got a 10" sub in the center compartment where the CD changer used to sit. Obviously, the cover's off the compartment and the sub sits at a slight angle. The amp is mounted in that same space.
Old Feb 21, 2005 | 09:37 PM
Adrian-S's Avatar
Adrian-S
If you stay with the stock system, how are you wiring the sub?
Old Feb 21, 2005 | 11:34 PM
mjb929rr's Avatar
mjb929rr
Heres a link to my setup. I am actually trying to sell it and it includes everything you need to add an amp to the bose headunit. http://forums.corvetteforum.com/show....php?t=1020157
Old Feb 25, 2005 | 12:46 PM
BBM98C5's Avatar
BBM98C5
If you stay with the Bose headunit, you have to use a line level converther hooked to both of your rear speakers. This will turn your speaker wire into RCA's. Then, you run the RCA's to the amp. My amp has a low level and high level input switch, which let me adjust my amp's power output to match the voltage of my signal. A lot of amps dont have this switch, so your sub may not hit as hard without it. Either get an amp like a JL 500.1 which has this switch or some amps have a line level input, which would let you put the speaker wire straight into it. The JL is AWESOME!!
To Sub Location
