Sponsored by: Innova
Light Weight Audio Nirvana ?
Old Mar 16, 2005 | 11:04 PM
lloaf's Avatar
lloaf
Default Light Weight Audio Nirvana ?
I would like to significatly upgrade my stock system, but because of performance priorities, do not want to add a lot of weight i.e. heavy subwoofers and amplifiers. Any ideas?
Old Mar 16, 2005 | 11:37 PM
snoopdan's Avatar
snoopdan
There is a trade off somewhere
snoopdan
Old Mar 17, 2005 | 05:20 AM
scott_fx's Avatar
scott_fx
wow... that was funny.....
i would probably suggest finding one of those small audiophile amps (there was a thread about them on here some time ago) and a good set of 3 way door speakers that.
for base...you'll pretty much have to cut corners here, why dont you buy a selfpowered tube and set it up to be quickly removed when you are going to go out to the track.
Old Mar 17, 2005 | 05:53 AM
Kale's Avatar
Kale
Neodymium subs! good luck finding them, cant think of one offhand
Old Mar 17, 2005 | 10:56 PM
Vate's Avatar
Vate
Pull out all the Bose crap and get an iPod (similar to Snoop's suggestion). The Bose HU and front spanklifiers are worth 15 pounds, easy. Better sound, better music selection, and net weight savings.
Or...
I like the idea of "remove it for race day". My heavy MDF sub enclosure in the rear compartment comes right out - two connections and it's done. The amp is trickier - you could rewire everything with quick releases, but it would still be a PIA to remove.
So, Bose out, lighter HU in, lighter door speakers in, ditch the vibrating paper plates in the back ("rear speakers"), put in an easily removable rear sub enclosure, and the lightest amp you can find.
Old Mar 17, 2005 | 11:14 PM
snoopdan's Avatar
snoopdan
im totally using that from now on to describe any rear fill.
Old Mar 18, 2005 | 12:14 AM
scott_fx's Avatar
scott_fx
on second thought... i have a 4x75 phoenix gold titanium amp and it isn't really that heavy. it runs my entire system (fronts and sub) and sounds great. I wouldn't worry about the amp weight, if a few pounds is gonna make a difference...go on a diet
Old Mar 18, 2005 | 01:01 AM
snoopdan's Avatar
snoopdan
Originally Posted by scott_fx
on second thought... ...go on a diet
you went there dood.
Old Mar 18, 2005 | 11:15 AM
knewblewkorvette's Avatar
knewblewkorvette
YOU GUYS ARE GREAT
That is exactly what I was thinking when I read the opening. Aura has always had those and now Critical Mass makes them. Critical Mass latest and greatest is awesome. A 10" or 12" at 18lbs, carbon woven cone, handles 3000watts, and has 3 1/4" of excursion
Old Mar 19, 2005 | 12:14 AM
muddpile's Avatar
muddpile
Do Planet Audio still make their NEO line of subs. They were an excellent speaker, weighed nothing and had very low mounting depth. Plus they were affordable.
To Light Weight Audio Nirvana ?
