Sponsored by: Innova
Quick Help (Bose)
Old Mar 27, 2005 | 03:38 AM
kabnvtt's Avatar
kabnvtt
Default Quick Help (Bose)
I need to know what to do about the am/fm antenna for the Bose gold system. I am swaping the bose for a sony deck and the sony has the standard plug receptacle but the bose does not. Is there a wire that is in the harness for the fm reception. Please help. Its a 92 ZR-1. TIA
Old Mar 27, 2005 | 09:31 AM
EatRice's Avatar
EatRice
You need a mini to standard antenna adaptor. Should be able get one anywhere you can get install supplies. It is also called GM antenna adaptor.
Old Mar 27, 2005 | 09:47 AM
kabnvtt's Avatar
kabnvtt
Thanks I will hit Best buy Or Jerkit City. But where am I going to plug it into the old bose unit did not have the normal antenna receptacle and the new deck does. Is there some type of seperate reciver in the car somewhere?
Old Mar 27, 2005 | 10:26 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
HeHeHe.................
Jerkit city!
Old Mar 27, 2005 | 11:02 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I believe the reciever is seperate, memory's not working but i think behind the seat ??
Right rear compartment in cargo area
Old Mar 27, 2005 | 03:52 PM
bogus's Avatar
bogus
the receiver is a module on the firewall. best reached by removing the glove box.
it is also the source for power and such.
To Quick Help (Bose)
