Sponsored by: Innova
wiring on 90 quest.
Old Mar 30, 2005 | 09:59 PM
mseven's Avatar
mseven
Default wiring on 90 quest.
I just got through re-doing antenna relay on my 90 and finally got it all working properly. There is only one hting I would like to do before I button it all up. Since I am still foolin w/ the metra set-up, this would be a good time to add the dimmer line from the deck (kenwood 898). Where would be the best place to tie into , I could not use the after market tie- in harness because of b. gold sys. (or so Iwas told). It is tied into the harness that did lead to the original deck for power only. speakers wired direct , and antenna from ccm. Anyone have ideas? Thanks m7
Old Mar 31, 2005 | 01:44 AM
bogus's Avatar
bogus
check the C4 Audio FAQ... it has a link for the dimmer wire resister fix. Use that wire.
