Sponsored by: Innova
Low Cost Monitors
Old Apr 2, 2005 | 01:48 PM
ltnate's Avatar
ltnate
Default Low Cost Monitors
Can anyone comment on the low cost monitors out there, ie...Lilliput,Avator, LM etc? Also is there an RGB/VGA adapter or do the monitors have to have an RGB connection for navigation?
Old Apr 2, 2005 | 02:07 PM
scott_fx's Avatar
scott_fx
haven't heard about avator or lm but the lilliput i've seen in person and it is a decent monitor and it's even a little brighter then my xenarc. The lilliput is available with vga and rca inputs. you can get a vga->rca converter but you'll be wasting your money. you'll need vga res. for smaller text. The reason why i purchased my xenarc over a lilliput (even though a brighter screen would have been better in a vert) was the build quality of the lilliput isn't as refined as the xenarc. Though, dont let that steer you away. A lot of people love the lilliput and have had little to no problems with it
for more input on monitors check out www.mp3car.com they have a forum dedicated to lcd displays..do a search there and you may find out more about the other monitors.
Old Apr 2, 2005 | 02:11 PM
ltnate's Avatar
ltnate
I guess I'm a little confused. What exactly is the difference between RGB and VGA? Can you use a VGA monitor with a navigation system. Once again, thanks for your information.
Old Apr 2, 2005 | 04:04 PM
scott_fx's Avatar
scott_fx
i missread your post, i thought you said rca not rgb.
vga is a higher resolution digital standard used in computer monitors, while rgb is a high resolutoin analog video standard
it goes:
coax--worst, carries audio and video on while wire
composite--carries all video info on one wire (aka rca)
s-video-- has two primary wires, luminance and chromanance
component--splits the video signal into 3 wires, red, green (usually carries sync), blue (This standard is also known as aka rgb)
Rgb is the best of these but it still lacks the ability to display the finer detail that vga signal carries.
to answer your question i guess i have to konw what kind of nav system you are talkin about. is it an aftermarket system, a computer system, or a stock c6 system.
Old Apr 3, 2005 | 05:54 PM
ltnate's Avatar
ltnate
Man you are great! I'm looking at an aftermarket Kenwood or Pioneer. I just want to make sure I get the right monitor.
Old Apr 3, 2005 | 09:04 PM
scott_fx's Avatar
scott_fx
if you are going with one of those systems you cant use a different monitor. i believe the pioneer's only nav systems are the avicn1/2 which the monitors are built in with the nav system. i'm not sure about kenwood but if it is a touchscreen nav unit you are most definately stuck with buying from the same manufacturer.
The monitors you have mentioned would be only good for aux monitors to display movies with. in that case you would have to check specifics on the h/u model but it should be just a composite out (rca jack)
Old Apr 3, 2005 | 09:27 PM
ltnate's Avatar
ltnate
Actually both companies have stand alone nav units without monitors. I guess I just need to see what type of connection I need to make it work. I appreciate you helping me out.
Old Apr 3, 2005 | 11:46 PM
scott_fx's Avatar
scott_fx
if you can post a link to the products i can check it out too.
Old Apr 4, 2005 | 09:02 AM
ltnate's Avatar
ltnate
Here is the link to the Kenwood model. Let me know what you think.
http://kenwoodusa.com/product/produc...productId=2627
Old Apr 4, 2005 | 09:22 AM
scott_fx's Avatar
scott_fx
there is no manual for that on that site but it looks like if you want to use the touchscreen feature you are stuck with getting a kenwood monitor. but if you dont want that feature then you can use any monitor with an rca vid. input
Old Apr 4, 2005 | 10:14 AM
EatRice's Avatar
EatRice
Itnate...if you decide to use the Pioneer I would recommend the Pioneer monitor. If you use the Pionneer monitor you will have all the touch screen controls of the nav unit. I do not think that works on any other monitor. I have a AVIC 80 in my truck and love it.
Old Apr 4, 2005 | 11:36 AM
raw122's Avatar
raw122
im looking at putting a monitor in my vet how does the Lilliput and other companies compair to clairon ,alpine and monitors like that,i want something with good res. im getting an indash dvd player to hook to it
thanks to info
ronnie
Old Apr 4, 2005 | 01:39 PM
scott_fx's Avatar
scott_fx
for just playing dvd's most of the monitors will be fine. xenarc's have a little better detail in the blacks while the lilliput is brighter.
I'm not sure about the other screens since i've never seen them in person.
Old Apr 4, 2005 | 04:37 PM
leolufse's Avatar
leolufse
Most of the guys on the 350z forum are using the Farenheit 7" monitors. I know nothing about it other than its inexpensive. I'm running a Sony HD65 and I've run an Alpine TME-M760. The Alpine had better resolution, but the Sony is 1/2 the price and still very nice. I like the alpine better because you can change sources w/out the remote control, so switching to the back up cam or nav is easier. I'd take Randys suggestion, buy the same brand monitor as your HU. If I went with the Alpine touchscreen in my 350z, I'd be able to control the Alpine DVD player and nav, and switch sources like I just described.
Old Apr 4, 2005 | 11:23 PM
ltnate's Avatar
ltnate
Hey Eatrice I've been waiting for you to chime in. Will the Pioneer fit without much mod? Don't know if you guys know but VrumVrum just sent me pictures of a HU/monitor kit which he makes. It makes intalling a monitor very very simple. I'll send pics to anyone who wants to see it.
Old Apr 5, 2005 | 01:21 AM
snoopdan's Avatar
snoopdan
You all suck. Now you got me looking at monitors / video head units.
Does anyone have pics of a monitor install in a early C4 ?
snoopdan
Old Apr 5, 2005 | 02:51 AM
scott_fx's Avatar
scott_fx
id like to see them
To Low Cost Monitors
Old Apr 5, 2005 | 03:22 AM
knewblewkorvette's Avatar
knewblewkorvette
snoopdan
I agree, you all suck
Old Apr 5, 2005 | 07:34 AM
raw122's Avatar
raw122
Farenheit sucks i have tried a few of them everytime a new model came out and the display is not bright and you can not view it at all from angles
and does vrumvrum make a mount for the c4 or c5s,i would like to see some for the c4's,i was thinking of moving my rearview mirror to a glass mount and mount a monitor where the mirror is now
Old Apr 5, 2005 | 08:22 PM
ltnate's Avatar
ltnate
id like to see them
Send me your email address and I'll send them to you.
