Sponsored by: Innova
C4 box question
Old Apr 4, 2005 | 03:53 AM
black_89_vette's Avatar
black_89_vette
Default C4 box question
89 Corvette
Rockford Fosgate P2S104 http://www.rockfordfosgate.com/produ...h%20Subwoofers
Sony Explod D500X http://www.cardomain.com/item/SONXMD500X
Rockford Fosgate CD/MP3 head unit RFX-9120http://www.rockfordfosgate.com/produ...Source%20Units
JBL speakers in hatch GTO936http://www.jbl.com/car/products/prod...er=GTS&cat=MEL
in doors JBL EC6.2http://www.mandalaynet.com/newjblec6182.html
Okay, I just bought the amp and sub and was going to put them in the driver's side storage compartment bin. The sub suggests either a 0.65 cu. ft sealed enclosure or a 1.0 cu. ft. ported enclosure.
What is the major difference between a ported and sealed enclosure in terms of sound? And, if I use the 0.65 cu. ft. sealed enclosure, would the measurements be 1 ft. x 1 ft. x 7.8" deep?
I really should go out and measure the actual thing, but it's late at night and was just wondering if someone has done something similar.
****EDIT****
I plan to put the sub in the storage bin and the amp behind the passenger seat, not them both in the storage bin.
Old Apr 4, 2005 | 04:57 AM
snoopdan's Avatar
snoopdan
have you looked at the subthump website? They have a c4 box on there, and I own one.
http://www.subthump.com/c4vette.htm
This is what my 10" Onyx sub looks like in my car, pic taken yesterday
Sealed is the way to go if you want a small enclosure that Typically takes alot of wattage. Vented enclosures are usually larger, but have lower end extention at higher volume. You pay into both types when considering power/driver specs/avaliable airspace. Mind you, this is a short and simple answer, and if you are really interested in getting technical, go CLICK HERE ...its pretty straight forward. If you want to get complicated, GO HERE .
Personally, I usually run sealed enclosures, most of the time I am limited on space. One of the things I like about sealed is that the bass is punchy and always clear. The downside to my preference is that it doesnt get nearly as loud as a vented enlosure.
Hope this helps!
snoopdan
