From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
C4 Dr Dons Bose CD replacement questions.
I have the factory Bose radio/tape player in my 88. How do I disconnect the antenna from the back of the head unit?
I'm trying to replace it with a used unit from Dr Dons that I bought off another Forum member. The Dr Dons unit has a sleeve like end for the antenna. What do I need to make the existing antenna cable connect to the Dr. Dons unit?
HMMMM, not sure why the doctors wouldn't fit. I did the same with my 88, and it matched. The only thing I can think of is that the pins for the plug in are smaller or larger. There is an antenna adapter available anywhere for this....
