Sponsored by: Innova
93 am/fm/cd
Old Apr 22, 2005 | 09:46 PM
bodi168's Avatar
bodi168
Cruising
Default 93 am/fm/cd
I have a 1993 with the factory am/fm/cd. I've recently started having a problem with the cd not wanting to load correctly when it's cold. The cd loads like it's stuttering, then when loaded the speakers sound like they have some type of short or interference, and the cd will not play. If you press the eject button the radio will play for only a second. You have to hold down the eject button for a long time to get the cd out. Then it comes out like it's stuttering. If I turn the heater on for a bit the radio seems to warm up and then the cd works fine.
Has anyone had a similar problem? Suggestions?
Thanks in advance.
_________________
Jeff D.. 93 Triple White Convertable
Old Apr 22, 2005 | 10:30 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Thanks in advance.
_________________
Seems to be the norm, get it repaired. Sorry, Dr. Don or Same Day Audio Repair.
Old Apr 23, 2005 | 12:39 AM
Bolt-On's Avatar
Bolt-On
I just had my CD repaired by same day audio repair. I'm very happy with the repair, it even plays CD-R's now (I don't think it did before). They are on ebay. It cost me $100 plus shipping.
Old Apr 23, 2005 | 07:52 AM
bodi168's Avatar
bodi168
Cruising
can you get me the information to contact they guy you used? sounds like that's my only option and yours is pretty reasonable.
thanks,
Jeff
To 93 am/fm/cd
