Sponsored by: Innova
Terk XM
Old Apr 27, 2005 | 09:19 AM
OzzyC4's Avatar
OzzyC4
Default Terk XM
Is the Terk XM add on unit worth using? It is priced right, if it works good.
Anyone have any experiance with it.
I am thinking of using it with my Pioneer DHP77DH and now is the time to do it since I am not finished with the install of my interior. thx.
Old Apr 27, 2005 | 09:57 AM
KenI's Avatar
KenI
I like the channel selection better on Sirius so I added the Siriur Starbase....
http://www.siriusbackstage.com/forum...ic.php?t=19470
it looks a lot like the XM Commander. I've had it for a couple weeks now and I'm very happy with it. Hope this helps.
Old Apr 29, 2005 | 02:56 AM
vrumvrum's Avatar
vrumvrum
http://www.xmfan.com/viewtopic.php?t=41216
I just bought the terk units for my Alpine instead of the Alpine XM unit. I couldn't find a reference to the Alpine XM unit on their website any more. I have an Alpine XM unit in my truck.
There are 2 required, a receiver and an adapter box which is required for whatever brand HU you need. The price was right at about $100 for both, however...
It didn't work.
No sound on channel 1 I called tech support, got through right away. We did a few tests while I was talking to him and he concluded I needed to return the receiver which I did.
Now the HU is displaying properly but still no sound. I'll probably need to replace the adapter box too.
Don't know if this is a reflection of the quality or my usual bad luck when it comes to making a purchase.
On the other hand, my daughter is very happy with hers.
Old Apr 29, 2005 | 08:28 AM
OzzyC4's Avatar
OzzyC4
I went ahead and ordered one on Ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5769714670
After the rebate from Terk the final cost will be $50.98.
Hopefully my bad luck wont run like yours, LOL.
Old Apr 30, 2005 | 02:15 AM
vrumvrum's Avatar
vrumvrum
Looks like I can't directly plug into the AI-Net cable I have running back to my disk changer. There are 2 pigtails coming out of the Terk unit to allow for daisy chaining. One has a female end and one has a male end. Apparently the correct plug needs to go to the HU.
The extension cord running to the CD changer has the same plug on each end. Interesting thought process by Alpine. It's like making an extension cord with 2 male ends and having an appliance such as a fan use the same female plug that's in the wall.
Old Apr 30, 2005 | 09:07 AM
OzzyC4's Avatar
OzzyC4
Bummer, time for a bit of cut and solder work.
Old May 1, 2005 | 04:55 AM
vrumvrum's Avatar
vrumvrum
Exactly what I did. The Terk unit has a 16 terminal plugin. I swapped the blue wires, the green wires, and the yellow wires. I was expecting to have problems with my CDA changer but it worked too.
Much better than having to remove the HU, locate the boxes under the dash and run the antennea back to the trunk area.
Old May 1, 2005 | 04:58 AM
vrumvrum's Avatar
vrumvrum
By the way, my antennea is mounted on the frame in the rear bumper area and I'm getting a signal in my garage.
Old May 1, 2005 | 01:12 PM
KenI's Avatar
KenI
Sounds good. Where did you pass the antenna wire through to this area? ...any pics?
Old May 2, 2005 | 03:07 AM
vrumvrum's Avatar
vrumvrum
I drilled a hole in the trunk just by the trunk latch. I also passed the wires to my nav antennea through there too.
Old May 2, 2005 | 10:59 AM
gpotski's Avatar
gpotski
I also drilled a hole through into the rear hatch compartment...
Old May 2, 2005 | 11:02 AM
KenI's Avatar
KenI
Thanks guys!
How is reception with it down there?
Old May 4, 2005 | 05:36 AM
vrumvrum's Avatar
vrumvrum
I have an Alpine XM unit in my all metal F250 XLT Lariat (dude) with the antennea on the roof. I'm in the Seattle area on the 47th parallel and I lose reception in the vette at a particular area with a hill and tall trees to the east.
The truck doesn't lose reception at all, but maybe once in a while.
Other than that no reception problems.
Old May 7, 2005 | 10:12 PM
OzzyC4's Avatar
OzzyC4
I installed the Terk XM unit today. My head unit was NOT listed on the Terk package, but Pioneer stated the headunit (DEH-P77DH)was XM ready.
The Terk units plugged right in and worked perfectly.
Old May 8, 2005 | 03:13 AM
vrumvrum's Avatar
vrumvrum
I take back my last post, it's not too objectionable, but I definitely lose reception a lot more than in my all metal truck.
I'm wondering if mounting the antennae to the metal framework of the trunk lid would be better.
Old May 8, 2005 | 08:06 PM
AMGPilot's Avatar
AMGPilot
That is the exact same unit I installed in my 2004 Coupe. It beats the hell out of FM Radio
I installed the antenna on top of the rear tail light opening lip and the reception is pretty good
It is a good alternative until I can save up the money to replace the entire sound system
To Terk XM
