Sponsored by: Innova
Amp in storage bin overheat ??
Old Apr 27, 2005 | 07:18 PM
steve haverl's Avatar
steve haverl
Default Amp in storage bin overheat ??
Has anyone put a 400-600 watt amp in the passenger side storage bin of a C4 coupe ?
Would it be necessary to cut some small vents in the lid (w/grilles for aesthetics) to get some air circulating ?
Any help appreciated. Thanks.
Old Apr 27, 2005 | 07:54 PM
Bolt-On's Avatar
Bolt-On
I've had a 600 watt amp (It's probably more like a 400 watt amp) in my passenger bin for about 2 weeks. I haven't had any problems.
Old Apr 27, 2005 | 08:05 PM
steve haverl
thanks. what brand ?
Old Apr 27, 2005 | 10:15 PM
-=Jeff=-'s Avatar
-=Jeff=-
I had an a/d/s 25x6 in the storage box with the ABS without trouble and just installed an Orion 225 HCCA int he same location and will know more later this year
Old Apr 27, 2005 | 10:32 PM
steve haverl
Thanks - your reply helped convince meto proceed.
Old Apr 27, 2005 | 11:09 PM
bogus's Avatar
bogus
I would monitor the amp, but modern amps run much cooler then they used to.
Personally, I like my amps out and available, if not for heat, but for access to tuning options.
To Amp in storage bin overheat ??
