Sponsored by: Innova
C4 ground location?
Old May 1, 2005 | 11:16 PM
vette-rookie's Avatar
vette-rookie
Default C4 ground location?
Im looking for a good ground location in the rear of the car for my distribution block. I dont like grounding to negative on the battery because I always get alternator noise that way. Any advise?
Old May 2, 2005 | 03:16 PM
bogus's Avatar
bogus
I ran 4 gauge wire back to the battery... no noise. Sadly, there is no ground back there that I would trust for this application.
use good gold connectors on the battery, too.
Run the big wires down the drivers side rocker panel. There is a channel perfect for this.
Keep your RCAs away - I run mine down the center console then out to the right... speakers go forward down the center and split at the dash.
Old May 2, 2005 | 03:31 PM
-=Jeff=-'s Avatar
-=Jeff=-
I have used either of the back 2 bolts on the driverside without any problems
Old May 2, 2005 | 10:28 PM
vette-rookie
Thanks guys, I might have to try the 4 gauge. The seat sounds like it would work, but Im powering 3 amps that combined will peak at 3360 watts. I just dont know If the connection will be good enough for that. My main concern is one of my amps (I think the Alpine) says not to use 12 volt negative for ground? I wonder if that would hurt it somehow?
Old May 3, 2005 | 04:52 PM
vette-rookie
I found it! I have a nitrous feed line that goes through the floor in the back. I just opened up the hole a little more and grounded to the scuffed frame with gold connectors then clear coated over it to keep it from corroding. Then sealed the hole back with silicone. Dont know why i didnt think of that before.
Old May 4, 2005 | 11:08 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Sounds like you got a good one, I used the seat frame bolts.
Old May 4, 2005 | 11:25 PM
DF's Avatar
DF
I did the same, but it was handy since the amps were under the seat (no worries about heat with my equipment, I have checked it out thoroughly)
To C4 ground location?
