Sponsored by: Innova
Accessory wire stupid question
Old May 14, 2005 | 04:57 PM
TJefferson2020's Avatar
TJefferson2020
Default Accessory wire stupid question
Hello Stereo Folks. I wandered over here from C2 to ask a stupid question.
My cheap receiver (JVC KD-S580) has a red wire off the back named "accessory" - what is this for?
Does it hook up to the "ACC" circuit or does it power some kind of accessory?
Thanks!
I need to come here more often...
pm
Old May 14, 2005 | 05:17 PM
rowdyt's Avatar
rowdyt
the accessory wire is also called the ignition wire or turn on wire. For the head unit to power on, you need a ground (usually black on the cd player), a constant (usually yellow on the cd player), and an ignition wire or accessory wire (usually red on the cd player)... If you are having to hardwire it, then you just need to tap into any component that doesnt get powered until you turn the ignition. C5's have one by the passenger floor fusebox, others have tapped into the ignition wire itself, and others have tapped into their Air Conditioner wires (I know you arent asking about a C5, just trying to speak from experience). Just get a volt meter and find a wire that is dead when key is out, then shows a power jump when you turn the key. Check behind the dash where the radio wires are first because you might have one there already, I was just trying to prepare you in case there isnt one behind the dash as to where else you could try to find one.
Sorry for the crappy answer, other guys on here can probably paint you better picture.
Old May 14, 2005 | 05:43 PM
TJefferson2020
Here's the set up - I just rewired my C2 using a painless 12 circuit universal GM type harness.
The deck has a yellow wire (B+) which hooks up to one of two wires - either "radio switched" or "radio constant on" wires (I chose "switched")
A black wire (ground)
A red wire (Accessory)
A blue wire (remote on for amp)
A bunch of speaker wires (4 channels)
I run the rca outputs to an amp installed behind the pass seat (2 channel, 400W)
Perhaps the accessory wire on the head is an alternate power source that works when the ignition is on "ACC"????
I got the deck free and it has no manual (not stolen....salvaged from a car i flipped...really....)
Does that help clarify?
Old May 14, 2005 | 05:46 PM
rowdyt's Avatar
rowdyt
you should've hooked that one up as "radio constant on"
and hook the red accessory wire to the "radio switched"
Old May 14, 2005 | 07:35 PM
TJefferson2020
AHA! the good news is I used male/female connectors. I'll switch 'em around.
thanks!
To Accessory wire stupid question
