Sponsored by: Innova
Sub recommendations
Old May 16, 2005 | 12:30 AM
Rgd2424's Avatar
Rgd2424
Default Sub recommendations
Any recommendations for a SUB and Amp. for stock system? 2004 Conv.
Old May 16, 2005 | 02:16 PM
Fasthotrod's Avatar
Fasthotrod
I have a Kicker Solobaric S10L7 sub powered by an Xtant 603 amp... couldn't be happier. There isn't a whole lot of space down in the back well (about 0.88 cu/ft or so) so you have to choose a sub wisely. I'm sure others will chime in with their personal preferences.
I am also a big fan of Orion equipment, but since they got bought out by DEI I have not been as impressed. Not to say that they are not as good as they were... I just got miffed when they stopped being "Made in the USA" like they used to be.
Regards,
Mark
Old May 17, 2005 | 01:31 AM
Rgd2424's Avatar
Rgd2424
Mark,
Thanks for the imput
Old May 17, 2005 | 08:23 AM
knewblewkorvette's Avatar
knewblewkorvette
Hi,
There is a ton of choices out there. JL makes a sub box (with sub) for a C5. There are two Forum members, VrumVrum and Subthump, that make boxes for the C5 also. You can pick your own sub then. Just be sure about the depth of the magnet and enclosure volume.
Same goes with amps, many choices. Once you decide on the sub, buy an amp that fits the impedence and wattage of the sub.
Good Luck
Old May 17, 2005 | 10:57 PM
dbirdhouse1's Avatar
dbirdhouse1
So many good choices....
To Sub recommendations
