Sponsored by: Innova
Which amp would you pick?
Old May 26, 2005 | 01:24 PM
94flavette's Avatar
94flavette
Default Which amp would you pick?
I'm looking for a small 2 channel amp and I am going to use it in tri-way mode.
I have narrowed it down to this Alpine or this MTX amp .
Which would you all go with? If you don't like those, feel free to give me a suggestion of an amp that is relatively small in size, good power, tri-way, and affordable.
Old May 26, 2005 | 04:04 PM
bogus's Avatar
bogus
what do you intend to run with this in tri-mode?
Old May 26, 2005 | 04:37 PM
94flavette's Avatar
94flavette
An 8 inch sub and two 4x6 plates
Old May 26, 2005 | 05:14 PM
OrthoAggie's Avatar
OrthoAggie
get a 4 channel amp or else you will need to have a passive xover for the sub or it will get the same freq as the plates.
this is a decent amp for the money
http://www.cardomain.com/item/MTX564
Old May 26, 2005 | 05:32 PM
94flavette's Avatar
94flavette
I'm going to use this in place after the amp before the speakers...
Old May 26, 2005 | 05:37 PM
OrthoAggie's Avatar
OrthoAggie
adding that to the price of the other amp you would be better off getting a 4 channel amp
Old May 26, 2005 | 05:41 PM
94flavette's Avatar
94flavette
SIZE is an issue! That is a small package...
And there is no way I'd be buying from Crutchfield. I actually found the Alpine amp on sale at Best Buy for a c-note...
I'm not building a huge system, just looking for something to power my two speakers and a small sub.
Old May 26, 2005 | 08:10 PM
Swany00's Avatar
Swany00
Veteran: Marine Corps
I'd stay away from Alpine amps.
Old May 26, 2005 | 09:34 PM
OrthoAggie's Avatar
OrthoAggie
i would still go with a 4 channel amp, you will have much better crossovers and you will be able to control the gain for the sub and for the speakers. that 4 channel amp is only 4" longer than the other amp which is not much
Old May 26, 2005 | 11:02 PM
EatRice's Avatar
EatRice
That is a hard choice, both are nice amps. Your intent will work but deiaggie is correct. If you can afford the extra 4" it would be better to use a 4 channel amp. The biggest problem with running an amp mixed mono is you have no seperate gain control. Often the sub needs more power but the mids and highs crap out.
Out of the two amps I would pick the Alpine.
Old May 27, 2005 | 11:43 AM
GKK's Avatar
GKK
I just installed this 4 channel amp and it is a lot of amp for the money http://www.thezeb.com/p-Profile-AP10...ier-109687.htm
I agree with the others, the amp is a very important part of an audio system and sacrificing a little more space will result in greater sound quality from your speakers.
Old May 28, 2005 | 09:33 AM
WildWolf's Avatar
WildWolf
it is not easy comparing apples to apples with a car amp....a lot of manufacturers rate their amps at 14.4 V. Cars fluctuate between 12.5 and 14.4. You will get significantly less power when the voltage falls to 12.5 volts. Good luck and take some pics when finished.
Old May 28, 2005 | 10:49 AM
knewblewkorvette's Avatar
knewblewkorvette
Old May 28, 2005 | 03:49 PM
bogus's Avatar
bogus
That is the upside to the JL Audio Slash series amps.
They have a thing called RIPS, which regulates power. So that output is always the stated wattage, as long as voltage is between 11.5 and 15.0 or so.
Old May 28, 2005 | 05:36 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
To Which amp would you pick?
