Sponsored by: Innova
C5 CD Change Plug?
Old May 30, 2005 | 01:53 PM
muncie21's Avatar
muncie21
Default C5 CD Change Plug?
Is this plug for the CD changer? If so, where's the other end of it come out?
Old May 30, 2005 | 06:45 PM
markcz's Avatar
markcz
Yes, that's the plug that connects into the CD Changer.
The other end is at (or near) the bottom right corner inside the passenger kickboard. It is split into two smaller plugs on that end.
What are you trying to do? If you want to add a changer or RCA input via a GM10-Aux you'll need to leave the cable installed.
Old May 30, 2005 | 10:03 PM
muncie21's Avatar
muncie21
I purchased a factory HU and changer and wanted to install them next week. I was looking the setup over to see if there was anything that I needed to order prior to the install.
From what I can tell, I just connect the factory HU to the 3 plugs behind the dash and then plug the CD changer in to the plug in the center rear-well. Am I missing something?
Old May 31, 2005 | 12:10 AM
markcz's Avatar
markcz
That should be it! The 'other end' of the changer cable is in the passenger footwell, but it is most likely plugged in to the stock radio harness which is plugged into the radio.
Old May 31, 2005 | 10:50 AM
muncie21's Avatar
muncie21
Thanks for the info.
To C5 CD Change Plug?
