Sponsored by: Innova
Cold Solder?
Old May 30, 2005 | 02:37 PM
Carl Johansson's Avatar
Carl Johansson
Default Cold Solder?
Anyone use those new solder guns that instantly heat up - and cool down? Do ya need special solder? is it a scam - or do the solder joints hold up aqs well as traditional?
Carl Johansson
Old May 30, 2005 | 03:55 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
haven't seen one yet, but if the solder joint is nice and shiny then it's probably ok.
Old May 30, 2005 | 06:17 PM
fishandfly's Avatar
fishandfly
THEY SUCK.
I just picked one up from Costco for $10. In perfect conditions it works ok, but the moment anything moves and their is no longer solid contact between the prongs and the metal it cools.
I tried making about 10 joints and finally went back to the old standby. I thought it would be easier to use inside the car since it needs no cord, but I got frustrated quickly.
Also, the gun is cheap. $10 to 20. But the tip that came with it already showed about 15% wear (the tip burns away) after 30 uses. A new tip costs $10.
I think it's crap and mine is heading back to costco.
Old May 30, 2005 | 06:54 PM
markcz's Avatar
markcz
I've never used a cold soldering iron, but I work maintenance in a tire plant and the equipment we have that was put together with cold solder joints is all crap. The joints don't hold up well to vibration or twisting of the wires. Do it the old RELIABLE way, you won't be sorry.
Old May 30, 2005 | 10:47 PM
knewblewkorvette's Avatar
knewblewkorvette
Thanks for the info, I was thinking about buying one.
Not anymore
To Cold Solder?
