Sponsored by: Innova
0 Gauge Installation!
Old Jun 1, 2005 | 07:59 PM
gogo4's Avatar
gogo4
Default 0 Gauge Installation!
Im using my 0 gauge wire but can't find an opening from the engine bay to the inside of the car anyone got some close up pics or a real detailed description on where i can pull this humango wire through ?
Old Jun 1, 2005 | 10:41 PM
EatRice's Avatar
EatRice
Passenger side kick panel. Remove the fuse panel cover and remove the sill plate. You have to look up under the dash you will see a piece of black rubber with foam on the back of it. Pull that down but do not remove it. Behind that you will see the fire wall. You will see a large rubber grommet to the right of the grommet you will see a slight triangular piece of the firewall. You can drill a hole there and insert a grommet. It is best if you remove the battery before hand. Then do a check to verify the drilling location on both the interior and exterior side of the fire wall. It is really a piece of cake and leaves plenty of room for 0ga. I have 0 going through there and several other wires in another grommet.
Old Jun 2, 2005 | 11:17 PM
knewblewkorvette's Avatar
knewblewkorvette
totally
Old Jun 2, 2005 | 11:57 PM
scott_fx's Avatar
scott_fx
i just rewired mine with 4 gauge in the location that eatrice had mentioned....one question...how in the heck do you guys hide 0 gauge wire???
Old Jun 3, 2005 | 01:04 PM
knewblewkorvette
I get the clear coated 0-guage, the wire then is invisible :o
Old Jun 3, 2005 | 01:10 PM
EatRice's Avatar
EatRice
You licky bastage.....I can never find that stuff. I am always told it is in stock but the packages are empty...lol.
Scott when it comes to 0ga it really is important to use a high quality wire. Generally the higher quality wire is alot more flexible then lower grades. The flexiablily allows the wire to be tucked away better.
Under my hood I ran the 0ga from the battery to the alternator under the wind shield wiper cowl. Only place I could really get the wire through the engine bay without possible problems.
To 0 Gauge Installation!
