Sponsored by: Innova
help me find the best amp....
Old Jun 17, 2005 | 01:46 AM
98stocker's Avatar
98stocker
Default help me find the best amp....
OK I am buying 2 idmax12's and i want to push about 2000 rms between them. I was thinking about the Earthquake PHD5000W It would supply all the power i need except i want NO distortion. Under 2 ohms the PHD produces some distortion. Is there any mono amps that i could use that would complement the IDmax's? Within a resonable price of course otherwise id use a Crown Macro Tech 5000VZ ($$$$3500+)
Old Jun 17, 2005 | 09:50 AM
knewblewkorvette's Avatar
knewblewkorvette
Unlike higher frequencies, us humans have a much harder time hearing distortion below 100 Hz. From what I've read over the years, most of us can't detect anything below 10% THD It drops to .1% THD at the higher frequencies.
Bottom line, the IDMAX sub are great subs and between two of them and that 3000 watts rms, your ears (and colon ) will hurt before you ever hear any distortion.
Old Jun 17, 2005 | 02:18 PM
leolufse's Avatar
leolufse
The JL1000/1 has good numbers. .05% THD and SN of 95dB. But it is power hungry and expensive.
I'd look into a PPI DCX1500.1. Its 1 ohm stable and will make over 1500 watts.
Or the Phoenix Gold Titanium 1200.1 is another good choice.
Old Jun 17, 2005 | 02:28 PM
simpleman68's Avatar
simpleman68
I have a 3 yr old PPI (4x125) and that thing rocks hard and clean. It is pretty power efficient and I'd put it up against anything rated at nearly twice it's power.
Scott
To help me find the best amp....
