Sponsored by: Innova
8" drivers in the door?
Old Jun 20, 2005 | 09:32 PM
p928gts's Avatar
p928gts
Default 8" drivers in the door?
i am building a custom componet set for the doors on my C5, and i was wondering if 8" drivers can fit the doors with plates? i know Vurmvurm can make cnc plates and i have been contacted by him for making the plates. however i need to know the largest size i can go for the speakers to be tested so see if they will match with the tweeter/mids that i have picked out. they are the BOHLENDER GRAEBENER NEO8PDR PLANAR TRANSDUCER . anyoen have any clues on this one?
Rob
Old Jun 21, 2005 | 05:47 AM
scott_fx's Avatar
scott_fx
i'm not sure of the depth myself, I know they are deep though. You will need to find some free air subs for this to work and plan on using sound deadener as those subs will rattle the door like... like... like a rattle?
Just curious though, why are you going with 8" speakers in the doors? are you not planning on running a seperate sub in the back?
Old Jun 21, 2005 | 09:13 AM
EatRice's Avatar
EatRice
I had MB Quart 8' midbass drivers in my door along with a 4" driver.
Old Jun 21, 2005 | 04:03 PM
p928gts's Avatar
p928gts
Default 8" midbass
Thanks for the info guys, i plan on using 8"midbass instead of a subwoofer. i would just like them to go as low as40hz flat. i have some but i wanna make sure they will fit before i tear into the door. i am using ribbon tweeter/midranges up on the pillars by the windshield......
when it is all said and done they will be able to handle about 250w rms with out even breaking a sweat.
Old Jun 21, 2005 | 07:03 PM
scott_fx's Avatar
scott_fx
sounds cool. take pictures!
Old Jun 22, 2005 | 08:13 AM
ILLUBEUTO's Avatar
ILLUBEUTO
3rd Gear
I Put 8 Inch Comp Memphis No Plate Required A Little Mod To Doors And I Have Memphis 5.25 In Rear Memphis 400by 4 And Memphis 300 By 1 A 12inch Sub In The Hole Of My 99 Vert. Sound Is Like Your There. I Recomend 8inch In The Doors It Gives Great Preasents Aim The Tweets At The Driver.
Old Jun 23, 2005 | 02:43 AM
p928gts's Avatar
p928gts
Default very nice!
i just looked those speakers up, very nice...... what did you pay for them?
Old Jun 24, 2005 | 05:35 AM
GSteg's Avatar
GSteg
Cruising
Nice to see more and more people using ribbon tweeters. What kind do you have?
To 8" drivers in the door?
