Sponsored by: Innova
Powered Sub install help
Old Jul 10, 2005 | 02:09 PM
FLC6's Avatar
FLC6
Default Powered Sub install help
I tried tapping into the rear speakers with no luck. I then tried the fronts.
It's a Bazooka tube.
Where can I get a clean source?
Old Jul 10, 2005 | 02:13 PM
Steve Germany's Avatar
Steve Germany
You will need to provide the info on the unit you are looking to tap into, Base unit/Bose or Nav HU to get the correct info.
Old Jul 10, 2005 | 02:58 PM
cmb13's Avatar
cmb13
Let me know how it works out; I'd be interested in doing the same, if I could figure out where to put it!
Old Jul 10, 2005 | 06:13 PM
FLC6's Avatar
FLC6
I have a Bazooka Tube that is self powered. I need to get a correct signal. I think I need high level inputs.
To Powered Sub install help
