Sponsored by: Innova
Avic-N2 Watching DVD's
Old Jul 20, 2005 | 11:45 AM
01c5z06's Avatar
01c5z06
Default Avic-N2 Watching DVD's
Has anyone figured out how to wire a bypass of the software on the N2 that allows passenger watching of DVD's while moving??
thanks
Old Jul 20, 2005 | 01:18 PM
simpleman68's Avatar
simpleman68
thanks
PM sent
Scott
Old Jul 20, 2005 | 03:51 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
It's my understanding that you cannot. Even if you ground the e-brake wire you still have the movement stuff contained in the unit. Simpleman, if you know a way, please IM me as well as this may bring me back to my first choice of HU, the N2.
The N1 you could do this. Thanks!
Old Jul 20, 2005 | 09:43 PM
EatRice's Avatar
EatRice
Run the rear video output into the rear view camera input.
Old Jul 21, 2005 | 10:23 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I got the DVD to work by routing the video output to the rear camera plug and adding a switch to the backup wire.
1.) Connect the Parking Brake lead from the hide-away unit directly to ground.
2.) Connect the Reverse-Signal lead from the hide-away unit to a switch near your seat that your can activate while driving. Connect the other side of the switch to 12V power.
3.) Loop the video output from the top of the hide-away unit into the rear-view camera input on the bottom of the hide-away unit.
4.) In the AVIC-N2 initial setup screen, turn on the rear-view camera feature.
there will be a text message at the bottom of the screen that's meant for actual rear-view cam use, something to the effect of "CAUTION: IMAGE MAY APPEAR REVERSED
Old Jul 21, 2005 | 04:38 PM
simpleman68
PM sent.
Scott
Old Jul 24, 2005 | 10:15 PM
01c5z06's Avatar
01c5z06
Followed We Gone's instructions and it works great! Even allows watching DVD and Nav at same time.
To Avic-N2 Watching DVD's
