I have read ALL these FAQs. There is some great info in here! Thanks to all that have taken the time to post their work and research. I still have a question on the best way to go.
I have a 2007 Coupe with NAV and Onstar. I want to keep the HU and have everything work as stock, but replace the Bose amp and speakers.
I have read conflicting info on the PAC AOEM-GM24 (good or bad?), tapping into the pre-amp outputs directly (no interface device), JL Cleansweep (pricey but works good), and even more options that are not mentioned here, like this interface device (which I used in my last vett 2002 Z06): AudioLink.
So from what I gather, I need to leave all the Bose amps and wiring in place to keep the functionallity stock, but can pull out the speakers. then (some how) tap into the outputs and go into my amps.
So what's the best way (best sound quality), to tap in and keep all stock functionality? Anyone?
